New TC Electronic Effects unit
Started by ToonLP, March 21, 2008, 08:27:08 PM
ToonLP
I am not young enough to know everything
LP R9 VOS with Mules
Marshall 2061X head with 2061CX cab
AngusYoung01
I was looking at that the other week, I'm very curious as to how it measures up to the G-System.
BigK
Quote from: AngusYoung01I was looking at that the other week, I'm very curious as to how it measures up to the G-System.
Same here, I would kill for a G system but this seems a little better in the cost department. Although it lacks amp channel switching and the ability to put certain effects before the pre-amp and the effects loop. But considering its TC it'll probably blow pretty much every other multi-effects unit out of the water.
PRS Tremonti - PRS Silverburst 594 - Ibanez RG550EX, RG570 & RG721FM - LTD SC 500 -  Schecter 006's - EVH 5150III 50w into custom Zilla Vert 2x12
I thought this would be alot more expensive than the G system - Its got analogue bits if I read right?
Like a less digital G system?
BigK
its around £450-500. Its got analog od and distortion (which is still digitally controlled) the other 6 effects blocks (the g-system has 9) are digital but are taken from the g-system. Its basically a cut down g-system with funky digitally controlled dist but without all of the extra switching and external loop options. still looks pretty awesome tho....
AngusYoung01
Quote from: JackBauer
Yup, and thats probably what would sway me to the G-System, being able to have say, a preset chorus'd clean, then using another preset to switch the amp to the other channel. It'd be killer.
BigK
Which is why I would probably Save a bit longer for a G-system. As I got so used to my HD147 (RIP) when I was gigging just pressing one footswitch for a completely different sound was awesome.
AngusYoung01
Not sure if I'd need one though... I'm not sure if I want any more effects any more... I've stripped right down to Guitar, amp, delay and wah. Nuno type thing.
