Blackstar (2nd time around)
Started by hamfist, March 23, 2008, 04:47:57 PM
ilÿti
Is it a type of noise you can kill with a noise reduction pedal? If so, I can live with it aswell.
Crawlers, Mule-7s
hamfist
Quote from: AndyB
Has anyone else noticed noise from the PSU or do I have just have a faulty one?
Yes, read original post
Modular1
ive got a ht-dual. i bought it to get a bit of valve action in front of the cheapy marshal mg30dfx amp i have, cos ive never really liked the tone of the thing.
i use channel 1 of the dual set to clean and the 2nd channel for distortion. id whole heartedly recommend this pedal if you cant afford a valve amp.
running my danelectro blue paisley overdrive into the clean channel of the dt-dual sounds great. ive also run my digitech hendrix pedal though it too (not extensively though) with no nasty hum issues.
ive since bought a fender champion 600 amp. it sounds great paired with this too.
jpmaxxy
Could anyone tell me how exactly the emulated speaker out works and what I'd need to do recordings onto a desktop pc?
hamfist
Quote from: jpmaxxyCould anyone tell me how exactly the emulated speaker out works and what I'd need to do recordings onto a desktop pc?
The speaker-emulated output is the same as the normal output but with an EQ applied to it, to simulate the effect of passing the signal through a guitar speaker.
 To record this onto a desktop PC, you will still need a soundcard with an integral pre-amp, or you will need some sort of pre-amp to amplify the signal before going into your PC soundcard's line in.
