Author Topic: Static problem  (Read 3724 times)
kellar
Static problem
« on: March 30, 2008, 10:49:35 AM »
Question for you guys that are more tech savvy than me.
I am getting a bit of static from my guitar. When I touch the cable going into the guitar it goes away. Also, when I have my fingers over the strings it goes away but as soon as I take them off it starts again. It's much worse with pedals plugged in.
I have swapped cables and it hasn't helped
I immediately assumed it was a grounding issue so I resoldered all my grounds and it's still there. I also switched out my input jack. Still there.
Any other ideas?
Static problem
« Reply #1 on: March 30, 2008, 11:20:24 AM »
it is a ground issue - the clue is that it stops when you touch the metal parts
if you could take a detailed pic of the cavity it might give us a clue whats happening
