Author Topic: Problem with my Laney  (Read 2028 times)
Stevepage
« on: March 30, 2008, 08:50:32 PM »
Hey guys. For some reason I'm not getting any sound out of my Laney VH100R. All the leads and connections are fine. But when I twiddle with the lead in the input it sounds like I'm messing with a kill switch. I've tried different leads, different guitars but the problem persists.
The valves look fine to me. What else could it be?
Simon D
« Reply #1 on: March 30, 2008, 08:52:53 PM »
Could be a fault with the input jack, or a loose connection to it. Is it the same on both channels? That could rule out it being a problem with the master volume.
Warpigs.
Stevepage
« Reply #2 on: March 30, 2008, 08:57:43 PM »
Now I'm confused. I just turned the amp back on and it's working  :?  wtf
Simon D
« Reply #3 on: March 30, 2008, 08:59:17 PM »
Amps are funny creatures, i guess  :wink: . I wouldn't worry about it too much, unless you gig with it of course.
Warpigs.
Stevepage
« Reply #4 on: March 30, 2008, 09:00:54 PM »
I don't just yet. I only use it for rehearsals. Luckily I have a back up plan if the amp decides to die on me. It's due for a revalve soon so I'll get the tech to give it a check over.
greg
    • http://www.guitaraid.co.uk
« Reply #5 on: April 01, 2008, 11:11:23 PM »
It could be an issue with FX send/return jacks. A quite often fault in guitar amps. Next time if it happens try to patch FX loop with a short jack lead. Remember there is actually a few FX loops in the VH100, so try all of them.
« Reply #6 on: April 02, 2008, 08:58:51 PM »
Quote from: greg
^ +1
exactly what I was about to suggest.  you could get the jack sockets replaced (fairly expensive if you have to pay for someone to do this) or just put a short patch lead between the send/return and that will sort it out (assuming this is the problem of course)
