Author Topic: Pedal screaming - ?  (Read 2413 times)
AngusYoung01
    • Heaven Asunder
Pedal screaming - ?
« on: March 31, 2008, 09:49:27 PM »
Well, thought I'd post this in here as it'll get more replies.. hopefully!
Basically, my DD3 screams like anything whenever I use the adapter. It's not a Boss one, so maybe this is the cause?
Also, it screams when its not in use,and gets higher when it's on.  :?
hamfist
Re: Pedal screaming - ?
« Reply #1 on: April 01, 2008, 07:17:57 AM »
Quote from: AngusYoung01
Are you trying to tell us that the pedal is fine when you use a battery ?
CHeck that the adapter is a "regulated" one. It doesn't need to be a Boss unit. Just needs to be 9V, able to supply enough mA's to supply the total of whatever pedals you are using it to power (the DD-3 alone needs at least 65mA), also needs to state that it is a regulated power supply. Also needs to be an "internal negative" connection to the pedal.
Mr Ed
Pedal screaming - ?
« Reply #2 on: April 01, 2008, 08:47:11 AM »
I think your pedal has a tiny Warlock trapped inside, what you're hearing are his cries for help.
Adam.M
    • http://www.healeyamps.co.uk
Pedal screaming - ?
« Reply #3 on: April 01, 2008, 10:45:11 AM »
or a screaming beautiful maiden awaiting rescue from a handsome prince.
opprobrium_9
Pedal screaming - ?
« Reply #4 on: April 01, 2008, 04:29:12 PM »
Warlocks and Maidens BE DAMNED!!!  ITS A DRAGON!
Don't you hear "Legendary Tales" a la '97 playing in the backround? (shudders at the thought  PDT_024 )
AngusYoung01
    • Heaven Asunder
Pedal screaming - ?
« Reply #5 on: April 02, 2008, 04:39:31 PM »
Aaaannyway  :lol:
Yeh sorry, it is fine with batteries. I'll just get a Boss PSA one.
Pedal screaming - ?
« Reply #6 on: April 02, 2008, 05:01:34 PM »
Kind of related, not deserving its own thread, and since this problem is pretty much solved.
Do digi delays self oscilate?
I think I have heard in reviews that analog can make a screamy noise when turned off, but could it be that?
AngusYoung01
    • Heaven Asunder
Pedal screaming - ?
« Reply #7 on: April 02, 2008, 05:21:06 PM »
How do you mean oscilate?
And its Digital. 8)
Pedal screaming - ?
« Reply #8 on: April 02, 2008, 05:31:00 PM »
Yeah, I know its a DD, you said :P
errm methinks oscilation be like this
AngusYoung01
    • Heaven Asunder
Pedal screaming - ?
« Reply #9 on: April 02, 2008, 07:01:51 PM »
I have no idea  :lol:
Pedal screaming - ?
« Reply #10 on: April 02, 2008, 08:21:20 PM »
Quote from: Will
Sounds like 1970s Dr Who Sound FX
