Changing valves in my TSL
Started by MDV, August 31, 2005, 07:41:14 PM
Ok, its time for a valve change.
At the moment I have stock valves (4 ECC83, 2 EL34, I dont know what make)
I'd like to change to something that makes it sound more aggressive and puts more low end in the sound. Can a different brand do this? Can other types of valve that fit the sockets do it without casuing problems?
Any help appreciated.
Cheers
Mark
A Groove Tubes 12AX7C in the V1 slot will give you more aggressive gain.
Cheers mate.
12AX7C is the same as ECC83, right?
The 12AX7 = ECC83.
The Letter C means it's a CHINESE tube. They make one that has an M after it, for MULLARD clone, but it's not as gainy.
Ahhhhh!
Okey dokey.
Will the chinese job still deliver decent tone? I wouldnt want to sacrifice tone for plain dumb gain.
Will it give me the added low end? (and can I have my cake and eat it please  :lol: )
HJM
Try both - I prefer the tone of the 12ax7M over the C, and then give it a bit more with my Big D pedal. Is V1 the main overdrive channel tube in the TSL? I don't have a schematic to check. Depending on the design, you may find some valves are only used in the dirt channel, some only for clean - allowing you to mess wit hthe clean and dirty tone independntly
Skybone
I've recently revalved my JCM800, but it had3 NOS pre amp valves in, so I left them there. I noticed some fizziness, so asked the question on the Marshall board, and apparently it's down to the pre-amp valves, so I put in 2 Sovtek 12AX7WC's, and left an ECC83M in the v3 position, now it sounds great.
If you go to //www.hotroxuk.com and look them up, it states that they're ideal for high gain amps.
Bibble.
Yeah HJM the V1s the main drive valve
Skybone, yeah I heard sovteks are better for aggressive sounds....but I for all I know they migh be whats in there already  :lol:
Thanks fir the help fellas, I'll start the hunt for the best sounding 12AX7 in the V1 socket.
Cheers
:drink:
Joe Dorcia
YO!
Give these gives a call //www.watfordvalves.com.
They can help you out if you ask them exactly what your after. The 12AX7M (which i use in V!) is good for adding the tone taken away by lines of effects pedals. It works a charm
Yours,
Dorcia #861
hmmm, aggressive tone & more lowend - sounds like you want some 6550s in the output stage.
As for ECC83s (aka 12AX7s), I only ever use NOS preamp valves as I have a huge stash of them and the tone is much better than anything currently being made. If I had to choose though, for a gainy amp I'd say most Chinese ECC83s tend to have alot of gain and cope well with high gain.  Dont spend a fortune of the 'super-duper gain-tested' ones Watford Valves sell, just the normal ones will be fine.
:twisted:
HJM
Quote from: HEAVIER THAN HELLhmmm, aggressive tone & more lowend - sounds like you want some 6550s in the output stage.
:twisted:
Well said!
