Author Topic: Can you buy a calibrated set seperately?  (Read 1446 times)
Modular1
« on: April 01, 2008, 09:48:44 PM »
what i mean is could i buy one pickup, then using the details of the order, get another one to make up a set at a later date?
or do they have to be at the workshop and made at the same time?
Antag
« Reply #1 on: April 02, 2008, 11:04:12 AM »
Yes -  if you buy a bridge model on it's own then you get the same bridge pickup as you would have got if you'd bought a calibrated set.
& if you buy a neck pickup later on to add to your existing bridge model, you'll effectively have a calibrated set.
The "calibrated" bit just means that it's the corresponding bridge & neck models in the same box for a bit less money....
