Author Topic: Hardware to match aged nickel pickups?  (Read 3776 times)
RadioElectric
« on: April 03, 2008, 01:58:30 PM »
Is there anywhere in the uk that sells tailpieces that would match the aged nickel pickups? I'm going to try ageing the one that I have over the weekend but if that doesn't work I'll need to try to find one somewhere.
« Reply #1 on: April 03, 2008, 03:40:27 PM »
check out  www.fatboyguitars.co.uk
when i wanted to do wartorn and aged hardware to match my miracle man set i asked tim how he achieved the look first
Antag
« Reply #2 on: April 03, 2008, 04:18:33 PM »
Eat a bag of heavily salted fish'n'chips with your fingers, then without washing your hands play in a hot stuffy room for a few hours, don't wipe the guitar down afterwards & leave it for a few weeks in the corner of your bathroom.... :)
« Reply #3 on: April 03, 2008, 04:45:55 PM »
Apparently you can use something called etchant fluid, a solution of ferric chloride(?) used for etching PCBs.  You can get it at Maplin, I think.
Never tried it though!
Is your current tailpiece definitely nickel plated?  Nickel tarnishes nicely but chrome doesn't.
« Reply #4 on: April 03, 2008, 04:47:36 PM »
well thats what i used in the end - a 30 second dip is more than enough
ferric chloride is the chemical name
doesnt touch chrome.. i think for that you need it suspended above hydrochloric acid.. not really to be done at home
Fourth Feline
« Reply #5 on: April 03, 2008, 07:52:47 PM »
There is another U.K. site called "Fake58". I do not know if they measure up to 'fatboy guitars' - but maybe worth a look ?
RadioElectric
« Reply #6 on: April 04, 2008, 12:49:21 AM »
Quote from: WezV
I think the current hardware is chrome, so I'll have to get hold of it in nickle once I know whether it's imperial or metric threaded. I already have some ferric chloride for circuit boards so that shouldn't be a problem. Do you have any pictures of what it did to your hardware?
« Reply #7 on: April 04, 2008, 06:54:25 AM »
Quote from: WezV
I wonder if it would work if done in a vaccum - I presume its the Chromium oxide layer on the surface of the material that stops this from working - No oxygen, and you're fine.
« Reply #8 on: April 04, 2008, 07:07:43 AM »
sure - but bare in mind i wasnt aiming for authentic
before dipping mine they were attacked with files, rasps and sandpaper   - then dipped
For a more authentic look i would just ip them for 10-20 seconds.. that should give you an old but not too worn look
