How do all.
As you may have gathered from the title of the post, I've put up with the pickups that have come with all the guitars I've had. I'm thinking its time that changed.
The guitar I'm thinking of putting through the change is an Ibanez AS50 – 335 copy.
The problem with it is that the bottom end is way to muddy and the top end is ear splittingly tinny.
My quandary is this - what Bare Knuckle Pickups should I go for?
I'm not a technical guitarist, I'm more interested in creating sounds. Check out
www.myspace.com/thelavaexperiments for a taster.
My live set up includes, Moog Ring Modulator, Line 6 Delay Modeller, Electro Harmonix Hog, Electro Harmonics Big Muff Pi, Cry Baby and an Ebow. I use a Grainger Blue Twin amp. All beats, other instruments, sounds etc come from Ableton running on a MacBookPro.
A pure but rich, clean, sustained sound is what I'm after. Not at all tinny or muddied. Due to the amount of effects I use big volume would be ideal but without a heavy/rough sound. I can get all the filthy heavy darkness I require from the Pi so I'd rather keep the guitar sound purer. (At gig volume the valves in the amp overdrive nicely to give a heavier sound anyway.)
Right, I'm sure I've bored the shite out of you enough for a Friday afternoon. I'm looking forward to your thoughts.
Cheers,
Fraser
