Quote from: JJretroTONEGODMy budget is £500-1000.
I am looking for:
an amp head, low watt, nothing over 20 watt. It has to have a nice breakup and be able to do clean through to classic rock and everything in between.
the BEST 1x12 cab, for use in any style, but mostly rock, built to last harcore gigging.
Ideally I'd like to know what your experiences are and what you'd recommend if you had that kind of money to play with.
regards,
Ben.
I would seriously be looking at a Vox AC15 or 30 Heritage head plus cab . Use the EF86 channel (you'll need a good EF86 -£25 from Watford valves), with a half decent TS-9 type OD and you'll be set.
Of the mainstream amps available in the UK at that price range and wattage, it is the best ! I've owned and tried almost all of the competition and, for what you want, it is the winner. It is a seriously classy amp.
Otherwise, look at Ceriatone. They cannot be beaten for value for money at the budget end of the boutique spectrum. I'm awaiting a handwired 50W plexi head for about £600 (including all import duties). They also do Matchless clones (and will do a 15W version of the DC-30 if you ask), and Marshall 18W clones - easily the best for your money at the sub-£1000 price range.
As for cabs, speak to Martin at Martamp for the cheapest, but highest quality, cabs you can buy in the UK at the moment.
My question would be - why a 1x12, when a 2x12 is still very portable and not that much more expensive ?
