Main Menu
String trees
Started by badgermark, April 07, 2008, 04:50:43 PM
badgermark
So on my Teles the open g string sounds horrible, and I'm guessing it's due to the string angle behind the nut. The sound is dull and lifeless and loses tuning quickly, so maybe thinking some string trees might help this out.
Been thinking about either these, which I have on my guitar already for the high e and b strings:
Or these, which just look cooler:
What's the verdict?
gingataff
It could be the lack of string tree, but I think you should check the nut slot  too.
If you def need a tree, I think most are ok, just choose what looks best. If you are worried bout the string sticking in the tree you can use some lubricant like Big Bends Nut Sauce on a non-roller type, or get a graphtech one if you don't mind the non-metallic look.
Alternatively (and a lot more expensive) you could get staggered tuners so you will get more of an angle over the nut.
I see a rainbow rising
Look there on the horizon
And I'm coming home
