Has anyone fittes a compensated nut to a Les Paul?
Started by Slarty, April 07, 2008, 05:00:55 PM
Slarty
Hi there,
Just wondering if anyone has fitted a Les Paul with and Earvana or Buzz Felching type nut?  If so is it worth while?  My G string gives me constant gip and some chords don't ring as true as I would like.  The intonation is fine.
Cheers,
O
Feline Guitars have fitted loads of Earvana nuts to all sorts of guitars - if you use the forum Search page for "Earvana" there should be plenty of info.
Gary
I have an Earvana on my Les Paul and have no tuning issues. Unfortunately I can't offer a before/ after comparison as it was already fitted when I bought it. My only gripe is the sharp edges - when you're playing live in an adrenaline/ sweat fuelled situation and you slide down the neck, it's a bit painful when you catch your hand on it.
Quote from: GaryI have an Earvana on my Les Paul and have no tuning issues. Unfortunately I can't offer a before/ after comparison as it was already fitted when I bought it. My only gripe is the sharp edges - when you're playing live in an adrenaline/ sweat fuelled situation and you slide down the neck, it's a bit painful when you catch your hand on it.
+1 i've had to round the edges of the nut with a needle file.
Antag
Feline fitted an Earvana to my Desert Burst.  I guess it works (no tuning/intonation problems) but I can't say I noticed any real difference & probably wouldn't get another one...
ilÿti
It is worth it! Not only did it make the intonation better, it also improved tuning stability a whole lot. And I even did a rather shoddy first timer job.  :oops:  Imagine what a pro can do.
Crawlers, Mule-7s
Slarty
Cheers guys.  I think I will go for one as I recently adjusted the intonation and some open chords still sound nasty.  It also seems to depend on how I tune the guitar - using 5th/7th fret harmonics or the 5th fret ocatves.  Harmonics seems the best overall way of doing it.
