Author Topic: Single Coil Set Help  (Read 2227 times)
ttosh001
« on: April 13, 2008, 02:13:09 AM »
I am using a Mesa Triaxis and ADA MP 1 Preamp into a Mesa 2:90 Power amp and I just recently purchased a Fender Strat that I want to replace the pickups in. I need a single coil set. I play everything from Contemporary Christian to Hard Rock/Metal and want to find a good pickup set that will be hum free as well as have really crystal clean tones while keeping good warm tones for Rhythm 's and leads.
Which set would be best suited for the above? It sounds like these pickups are some of the best around. I just want to make a wise purchasing decision if possible.
Thanks,
Tim
« Reply #1 on: April 13, 2008, 10:07:03 AM »
Hi Tim, welcome to the forum.
Your question is too hard for me to answer fully - I've only used one BKP strat set so far, the Irish Tours. I play them through a POD XTlive and studio monitors. I chose them because I play mostly blues and blues/rock.
I'm finding the ITs very versatile - they do work well on my more "rock-metal" amp patches that were mainly set up for humbucking guitars.
For me, they also clean up nicely - but "crystal clean" I'm not so sure about - not something I tend to use a lot  :lol: I'm usually looking for that warm, live, just-breaking-up, sort of Strat sound.
Having said that, I've been experimenting with sounds this weekend, and I am planning on trying to create a "clean" patch that I like - and the strat is what I'll be using. I'll post again if I find something amazing I didn't know about these pickups!
In my strat, the ITs respond very well to volume and tone control use (I'm wired for a master tone) - and there is a huge variation in tones I can get with the guitar controls alone before touching the amp settings.
On the hum-free question, they're just like other strat pickups I've used over the years - hum comes with the territory, if you want "that" sound. And I think this applies to all of the BKP strat pickups. You just need to make sure the guitar's shielding is up to a highest standard possible if the hum worries you. I've never bothered though...
You can order the middle pickup RWRP (reverse-wound, reverse-polarity) which gives you hum-cancelling in positions 2 and 4, and increases the strat "quack" in those positions slightly. I did this with my set (partly because the Texas Specials I was replacing have the same), but I didn't really need to - even though I play in the living room with the TV and a computer on at the same time! Yes, I get some hum, but no more than on any other standard single coils.
Hopefully that gives you a start, and some other folks with wider BKP single coil experience can chip in. I'm certain that Apaches are going to get mentioned for crystal clear (I'm actually planning on getting a set myself for another strat).
Elliot
« Reply #2 on: April 13, 2008, 12:02:26 PM »
I would also think Irish Tours, but for crystal clean to rock I would actually say Mother's Milks.
No BKP pickups are hum free, because they are true single coils - but then few valve amps are hum free.  If that is the essential point look at noiseless pickup manufacturers or the Suhr system.
« Reply #3 on: April 13, 2008, 05:15:17 PM »
Yeah I'd echo what Elliott has said regarding the hum. Having said that I have no issues with my BKP set. I haven't tried IT's and have tried a friend's guitar with Mother's Milks. Personally I'd opt for the MM's or a set of Apaches-they both do extremely good clean and warm Strat tones and you can push them into that "just breaking up" zone and they respond well.
ttosh001
« Reply #4 on: April 14, 2008, 04:49:32 AM »
Thanks for the responses. They have been very helpful. I am going to spend some time listening to clips on the site to also help me decide. I think whichever one I decide I will be quite happy!!
Thanks again for the responses.
