November 21, 2026, 11:41:32 PM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Guitars, Amps and Effects
can i sell my hotplate?
Started by goddamn electric, April 14, 2008, 02:30:16 PM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
goddamn electric
Bantamweight
Logged
If i were to buy a marshall vintage modern head (which i believe has a master volume) would i ever need to use my hotplate? im not really in the know with master volume amps but from what i understand the master volume would let my run the tubes hotter and keep the volume down like an attenuator would. is that right?
cheers
Light Heavyweight
Logged
#1
April 14, 2008, 02:33:14 PM
Nope - wrong :)
A master volume limits the signal getting to the power valves, so you just hear pre-amp distortion. A Hot Plate limits the signal getting to the speakers so you hear both pre-amp and power amp distortion.
I'd keep the hotplate if you already have one ;)
goddamn electric
Bantamweight
Logged
#2
April 14, 2008, 02:40:47 PM
cool,thanks for the advice twinfan, so what would i do? open up the master volume and then attenuate it to keep the volume levels lower?
Acolmiztli
Flyweight
Logged
#3
April 14, 2008, 02:41:52 PM
Exactly. You'd run the master volume pretty loud, and then use the attenuator to lower it to a more acceptable level.
goddamn electric
Bantamweight
Logged
#4
April 14, 2008, 02:44:59 PM
ok cheers guys, its a pretty stupid question i know, i just wanted to be sure, ive never owned a master volume amp so i was just checking.
Light Heavyweight
Logged
#5
April 14, 2008, 02:55:13 PM
No probs!
The Hot Plate is like an external volume control, so you can crank your amp to where it sounds great with the valves running nicely, then lower the actual volume.
Print
Go Up
Pages
1
User actions
Forum Ringside
User actions
Print
