Speakers again
Started by Woogie, April 17, 2008, 06:44:00 PM
Woogie
Going to go and sort out my new cab when my Laney sells so I was just wondering what speakers you guys would recommend.
I`ll be running a JCM800 2203/JMP (both 100w) into a 2x12.
These sorts of tones:
http://www.youtube.com/watch?v=h86Biyx1-dk
http://www.youtube.com/watch?v=jSNuIzw9VfU
http://www.youtube.com/watch?v=xAvFTGVJuAo
Stevepage
What about Celestion G12T-75's? A classic speaker that was used in old Marshalls.
Woogie
Hate the 75's!! They sounded so fizzy and scooped when I played a Jubilee head through them.
Cheers though
G12H-30s, no question
G12M-65s would be my next suggestion
for slightly more modern tones with a fatter bass end, Classic Lead 80s.
Erm yeah, and I believe there are a few 75s in seconds out  :roll:
From knowing what you want, sidewinders :P
Woogie
Need to check for those sidewinders again Will
Stevepage
Quote from: HEAVIER THAN HELLG12H-30s, no question
They're modern sounding and fat but they do have alot of presence in them. So if the JCM800 is sounding bright, the CL80 may not be to best option if you like a warmer tone.
Maybe try the Eminence Red Coat
G12H Heritages or Hot 100s would work well I think  :)
Woogie
What are the HOT 100's like?
G12 heritages would just blow surely?
Ah - sorry.  Missed the 100w bit!
Hot 100s are a balanced speaker with a good full bass and smooth highs.  No nasty spikes or 'charcter' to deal with.  You get out what you put in.  I've played them in two different 2x12s and they sound superb.  Plus they're 97dB rated so you can crank your amp a bit more for the same volume as 100dB speakers like V30s  ;)
Woogie
Cheers TF, what about the mids on them?
They're there, but not obtrusive.  In a lot of ways they have a fairly flat EQ, but they're not bland sounding.  They're "neutral" and let the character of your amp really come through.  I'd dismissed them even after good reviews from others as I saw them as cheap, nasty speakers.  I was wrong.  As "martinw" will tell you I'm a picky git with bat ears and I like them a lot.
For about £60 A PAIR you should give them a try!
http://www.lean-business.co.uk/eshop/index.php?main_page=product_info&cPath=14_15&products_id=68
I vote for sidewinders too
Will just got some and that s what i put in my 2x12 when I took the EVMs out
Power handling is 150W each - so a 2x12 handles 300watts
The guy Will bought from did have another 4 but don't know if he has anymore
Na, Phil  King got them. Next time he is coming over or something.
Quote from: Stevepage
I used them with a Fender Tonemaster head and they were a good match, wouldn't say they were a bright speaker imo - just PHAT, chunky and begged to be driven hard with overdrive.
