Author Topic: Les Paul + Holy Diver bridge + MM neck + 5150 pedal + 15w qb  (Read 4835 times)
« on: April 22, 2008, 02:51:26 AM »
my friend recorded more clips my holy diver bridge and his miracle man neck in my ex-les paul copy (brazilian mahogany, imbuya top, brazilian rosewood fretboard)
he recorded this clip with my Wattsom Cube 60 (the cr@ppiest 15w cube ever, shitety 8" speaker), a solid state Zambelli 5150 pedal (FET instead of tube gain stages)
he used a cheap pc mic, a danelectro dan-echo on the solo clip, a wylde overdrive on the rhythm clip
the solo clip is first the holy diver, then the miracle man neck on the metallica and steve vai part
the rhytm clip is the holy diver only
opprobrium_9
« Reply #1 on: April 22, 2008, 04:41:47 AM »
tone on the first clip is a bit cr@p, but you can hear the serious chunk goin on in the tone.  If that badboy was on tubes it would be sick!
second clip sounded much better.  i don't know if it was because there was a lot of reverb on or what but it sounded pretty good!
  • Truly bad since 1972
« Reply #2 on: April 22, 2008, 02:43:15 PM »
zambelli?
« Reply #3 on: April 22, 2008, 03:10:53 PM »
Quote from: opprobrium_9
the suckness isn't in the absence of tubes
here's the guilty one:
this is the worst 15w cube ever made
gorilla amps sound like bogners next to this
« Reply #4 on: April 22, 2008, 03:16:54 PM »
Quote from: sgmypod
zambelli?
zambelli is my bandmate (not the guy that recorded the clips)
he makes pedals and tube amps
you can here his first amp here:
http://www.soundclick.com/zambelli
it's based on engl fire and powerball amps with a soldano style power section
the second one will be mine, but bogner and splawn based :D
he modded my framus cobra and my wylde overdrive too
« Reply #5 on: April 22, 2008, 03:26:21 PM »
cool guess in brazil
Benny from Crossroads
« Reply #6 on: May 18, 2008, 08:23:18 PM »
Quote from: Eric Hellstyle
Oh my God !!!  you poor thing, you need a tube amp my friend , you will be in 7th heaven when you have one.
Benny
JJretroTONEGOD
  • JJ Retro w/Mule + BKP90
« Reply #7 on: May 20, 2008, 12:17:15 AM »
Quote from: Benny from Crossroads
Benny
can I buy this? £8.50 straight out offer!
