Neck reduction
Started by Ian Price, April 24, 2008, 07:17:58 PM
Quick question for you all. Would it be possible to reduce the thickness of a neck on a set neck guitar? Might sound like a stupid question but I have no idea if it is theoretically possible!!
opprobrium_9
Well it depends where you want to reduce the thickness.  I would say if you wanted to bring the thickness down on the neck you could do that.  If you wanted to do that on the body you would have to be very careful about how much you removed on the neck joint.  :)
didn't jimmy page have this done?
i wont do stuff like this unless:
a) its a cheap guitar and teh customer is prepared for the risks
b) i have an x-ray of the guitar neck so i know how much is safe to remove
but i will say that sometimes removing the cheeks of a round neck can make is seem much thinner without actually removing the all important wood behind the truss rod or affecting stability much
yeah, jimmy page did it... if you have a vintage gibson with a fat neck you can probably do it too  :wink:
A 1958 Les Paul is cool to do that, but I think the 59 is the right one for this flight!  :lol:
I know Peter Frampton had the neck of his old 3-pickup Les Paul shaved.  And didn't Scott Gorham have it done to his LP Deluxe? (or was it that he used that model because it had a thin neck? :? )
I can't imagine why anyone would want to reduce the thickness of a neck, though!
Quote from: WezVi wont do stuff like this unless:
What do you feel about removing the finish of a neck?
Quote from: Philly Q
Usually people who likes Ibanezished necks... Some Strat players too...
But they must know that a LP with a thinner neck will sound probably less "full" than normal...
Thick neck FTW!  :twisted:
goddamn electric
I used to like thin necks, but now i like thick necks.....thats a pretty boring story. sorry.
Quote from: goddamn electricI used to like thin necks, but now i like thick necks.....thats a pretty boring story. sorry.
Stories about thinner necks' addicteds going to a healthy life always are welcome!   :P
:D
rather than strip a neck i would just knock the shine off it - that way it can still be buffed up if wanted.. again it depends on the value of the guitar but i dont like doing irreversable things to expensive guitars
ToneMonkey
I reprofiled a neck once (albeit a bolt on).  Wasn't too difficult but you have to be really really REALLY careful not to go through into thr truss rod cavity.  It's also amazing how much different it feels once you take off the slightest bit of wood.
Personally though, I'd say that the risk of knackering a perfectly good guitar would be very high.
