Author Topic: Technical Question - pickups & output  (Read 1937 times)
GuiTony
    • guitar building blog
« on: May 04, 2008, 10:37:35 AM »
I have a few spare pickups lying around, which I decided to test with my multimeter.
A couple of Wilkinson P90s (new, I believe) gave me output ratings of 7.5 Ohms.  Which sounded about right.  A Wilki SC had a slightly lower output reading, but still above 5 Ohm.  That suggests to me that my multi-meter is working properly, and I'm using it properly.
When I tested a Seymour Duncan SH1-N, the output reading was way down - around 2.5 - 3ohms.  Does that mean that the p/up is bust in some way?
« Reply #1 on: May 04, 2008, 10:53:47 AM »
Something's wrong, it should be over 7K.  Is it a 4-conductor model?  If it is, you should be able to tell if one coil's defective.
I have a nearly-dead DiMarzio stacked Tele pickup that's supposed to be about 9K but is actually less than 2K - it turned out that only the bottom, noise-cancelling, coil was working.
GuiTony
« Reply #2 on: May 04, 2008, 11:04:29 AM »
Thanks for the quick reply.  Yes, it's a 4 conductor model.  I tried testing across the black to white wires, and got 3 ohms.  Then I tried across the red to green, and got the same output reading.   :?:
« Reply #3 on: May 04, 2008, 11:06:58 AM »
Hmm, that's odd.  Have you got red and white twisted and/or soldered together (for standard humbucking operation)?
« Reply #4 on: May 04, 2008, 11:15:15 AM »
Quote from: GuiTony
if itsa duncan i think you have just tested each coil seperately, join the red and white together and test from black to green
GuiTony
« Reply #5 on: May 04, 2008, 11:15:30 AM »
Just twisted the red & white together, and testing those together to the black wire, and still getting a reading of just over 3 ohms ???
« Reply #6 on: May 04, 2008, 11:21:34 AM »
Quote from: GuiTony
Yeah, you're still only testing one coil.  Leave them twisted and try black to green, as Wez suggested.
GuiTony
« Reply #7 on: May 04, 2008, 11:24:29 AM »
Quote from: WezV
Quote from: GuiTony
Top man  :D
I now have a reading of 6-7 ohms ... still not as high as I'd expected, but at least it's getting better.
Thanks Philly too.
