Bad SG GAS Att: Henk
Started by samoth2, May 12, 2008, 08:10:58 PM
samoth2
I was actually saving up for a Miniplex MKII, but then I see this
It's a 1973 SG, and it just looks amazing. However it has a big break in the neck, which is said to be professional fixed. I'm just afraid it might be a problem, but I haven't had problems with my Hamer.
So does anybody know anything 'bout SG from that period? How are they?
Brakes are quite common in SGs I allways thought.
if its done professionally, I reckon it should be k.
samoth2
Quote from: noodleplugerineBrakes are quite common in SGs I allways thought.
With my Hamer I could even start collecting guitars with neck breaks :D
Antag
Yeah, they are beautiful guitars - at least, mine was until it fell down some stairs :(  If I could have any SG, it would be another one of these (don't believe some of the tosh you read that all 70s Gibsons are no good)
Come to think of it, ask the buyer where he got it - it looks like exactly the one I had... :)
samoth2
Quote from: AntagYeah, they are beautiful guitars - at least, mine was until it fell down some stairs :(  If I could have any SG, it would be another one of these (don't believe some of the tosh you read that all 70s Gibsons are no good)
Sound good, I really wanted a SG for a long time, and i really like the looks of this one. And if it plays good to it would be great.
If it was well fixed, then now its probably the strongest part of the neck. If a bit of a vibration stopper (glue doesnt transmit vibration well) but you probably wouldnt be able to tell the difference if its well done.
If not....well, you get the idea.
That said, now I'm no luthier, but, if it was well fixed you should barely be able to see it??
break behind the nut and professionally fixed = no big deal
However a Fargen MiniPlex would be VERY templting too  :lol:
samoth2
Quote from: hunterbreak behind the nut and professionally fixed = no big deal
Yeah it would, but I have no need for a real amp at the moment  :lol:
Tellboy
Yes - much better than having a break at the neck/body joint. Also you are lucky as this is a "type 4" SG. They were still making the type 3 SGs in 1973 which I think were the ugliest SGs ever made. They had a raised triangular Les Paul type scratchplate and the controls were pre-mounted on a seperate plastic plate.....
        ....Ugh ... a real minger.... PDT_009
I think that "minger" looks great!  I'd gig it!
Tellboy
Quote from: TwinfanI think that "minger" looks great!  I'd gig it!
Each to his own Dave  :) ... Actually they could possibly become valuable as they were only produced between 1971 to 1973 and were very unpopular (SG sales dropped to an 'all time low' whilst these were being made) Also quality control at this time was "frankly, appalling"...god must have been bad.
samoth2
I decided not to buy it, since i didn't have the chance to try it, and i heard that the Norlin Era gibsons were not the best.
This also means that i will get a miniplex sooner :D
opprobrium_9
i think the minger would look ace if it weren't for that black control mount UGGGG  :?
Quote from: TellboyThey were still making the type 3 SGs in 1973 which I think were the ugliest SGs ever made.
I'm with you on that one.  There are so many bad design features - the pointless pickup mounting rings, the needlessly raised scratchplate  (why not flat on the body?), the ugly plastic control panel.  And the insides of the cutaways aren't contoured, which looks dreadful, like they just gave up before the guitar was finished.
Plus it has the "90 degree" neck pitch so the end of the neck is raised and the strings are parallel with the body, which I don't mind playability-wise, but it looks ugly.
I saw a couple of those around Denmark Street a few years ago and they weren't too expensive, but they've probably gone up since.  I don't follow the vintage market.
