making a fx pedal for mate...hopefully
Started by varkunus, May 14, 2008, 06:51:34 PM
varkunus
Heya well since im doing a GCSE in electronics. I would really like to make a pedal, either for myself (guitar) or mate who plays bass. I was thinking maybe a fuzz face since the diagrams look simple. Could someone give me some advice on a good basic starting point, and should i order any special components like gyranium transistors, or just use to stocks to see if it works. And anyone got any websites with reliable/proof check circuit diagrams? Otherwise its gona have to be *search* fuzz face circuit diagram  on google images
Not sure, but you could order parts (or just the whole thing) off BYOC maybe? Not sure if that's allowed for your GCSE.
varkunus
no im not doing it for my GCSE since it wont get me enough marks for an A. But i just wana make one for fun? Know anyone that could help me out never know i might end up being the next fulltone
Then go BYOC. They have kits from easy to complex but worthy of every minute of assembly.
Quote from: varkunusno im not doing it for my GCSE since it wont get me enough marks for an A. But i just wana make one for fun? Know anyone that could help me out never know i might end up being the next fulltone
I got an A in electronics GCSE, and to be frank, a guitar pedal would be plenty to get an A, as long as you do enough research into designs/ different circuits, etc, market competition, all information very easy to attain, since there are so many circuits about, and so many manufacturers.
Kilby
If you want to build a Fuzz Face (or Tone Blender) then I would suggest buying a matched pair of Ge transistors.
The other option is to build one using Silicon transistors as they are consistant in their specs
Goodbye London !
Kilby
Duplocate message
Damn I hate the proxy I have to use in work
Goodbye London !
varkunus
well no ive already started my project, but what i meant is because my teacher does not have any experiance in the subject if anything goes wrong with a more complex design im stuffed. Anyway im making a safe alarm now anyway, with locks, and smart water and automatic arming between non working hours.
Anyway i dont really want a kit, i would like to create my circuit board using PCB wizard or such software, just need decent circuit diagrams for a fuzz face, and trying to know what components will work well? Could i use silicon transistors or will it sound like shitee
Kilby
For a Silicon version try http://www.runoffgroove.com/sili-face.html though there are several others versions around.
The handy thing about Runoffgroove is that you don't need to buy (or etch) any PCBs
Dave Gilmour used the Si version from about 1969 to 1974 and he sounded pretty good (to me). Transistor choice can make a difference in the tone
Goodbye London !
varkunus
maybe its my noobiness, but whats the 100pF do? I assume its a capasitor/
And also is the GND the input and output?
varkunus
ok ive just designed the circuit using PCB wizard, and im wondering  is the GND rail at the bottom posative? I assume it is. So in is for the input jack i guess and vol is where an ounput jack is attached i assume?
Quote from: varkunusmaybe its my noobiness, but whats the 100pF do? I assume its a capasitor/
yes, it's a small capacitor - it's function in this circuit is to tame the top end a little and smooth things out.  you could omit it from the design and the pedal would still work fine and sound a little sharper.  or, you could increase the value to 220pF, 330pF, 470pF etc... for progressively smoother treble.  of course, you get to a stage where it will be too smooth/dull.
Quote from: varkunusok ive just designed the circuit using PCB wizard, and im wondering  is the GND rail at the bottom posative? I assume it is. So in is for the input jack i guess and vol is where an ounput jack is attached i assume?
if you're using NPN transistors like in the link above, then your ground would be the most negative end of the voltage source (i.e. battery -'ve to ground, battery +'ve feeding the collectors).
the classic Fuzz Face design is commonly called positive ground since  the 'ground' is connected to the battery +'ve and PNP transistors are used.
for simplicity, I'd use the NPN design for a first pedal, it's less troublesome and the transistors are readily available.  use transistors that are cheap and easily attainable like 1N3904s - they will sound good in a Fuzz Face circuit too.
also, that 100uF cap from +9v to ground isn't necessary if you're using a battery, just leave it out.  it's there to smooth the supply out when using wall-wart power supplies.
varkunus
well ive printed off the circuit i designed and taking it to my teacher
