Author Topic: EQ pedal to tighten up my amp sound  (Read 8972 times)
hhcave
« on: May 15, 2008, 04:24:03 PM »
Hi,
Could anyone recommend an EQ pedal that would be good for tightening up the high gain channel on my amp? It's a Mesa F-50 and the gain is not quite tight enough for Melodeath stuff...
Cheers
Gisbon Les Paul Custom with MMs
Bodenhamer modded Maxon OD808
Mesa/Boogie F-50
Marshall TSL 2x12
Stevepage
« Reply #1 on: May 15, 2008, 04:41:38 PM »
The MXR 6 band EQ. Stick it in the FX loop too.
Or you could use an overdrive pedal in front of the amp with the level set to max and gain to 0.
« Reply #2 on: May 15, 2008, 05:24:17 PM »
Overdrives seem to tighten better than eqs, at least in my (limited) experience.
« Reply #3 on: May 15, 2008, 05:36:36 PM »
stock gwEm answer: Monte Allums "plus" mod Boss GE-7
« Reply #4 on: May 15, 2008, 06:15:43 PM »
Quote from: _tom_
+1
Rather get a drive pedal, lower the gain on the Mesa and kick it with the Overdrive. Success depends on the frequencies of the boost as well as the delicate balance between pedal gain (low) pedal volume (high) and map gain (medium) ...
« Reply #5 on: May 15, 2008, 06:59:09 PM »
you can put the EQ in front of the amp, so you can cut some bass from the miracle man, and add high mids and set a high level of output
hhcave
« Reply #6 on: May 15, 2008, 08:06:20 PM »
Hmm i think i want to go for the EQ option though because i really want to use the amps distortion (I grown to love the F-50s distortion) and i'm trying to minimise the amount of pedals in the loop to try and save the tone...
What would you say are the best EQ pedals for the job?
Mesa/Boogie F-50
Marshall TSL 2x12
waves
« Reply #7 on: May 15, 2008, 10:42:06 PM »
I know you're set on an e.q. pedal, but having a tubescreamer type pedal in the front of the amp with the drive on 0, tone where you want it and the volume up a bit work wonders since they essentially remove some of the bass frequencies.
« Reply #8 on: May 15, 2008, 10:44:30 PM »
Quote from: waves
I know you're set on an e.q. pedal, but having a tubescreamer type pedal in the front of the amp with the drive on 0, tone where you want it and the volume up a bit does wonders since they remove some of the bass frequencies.
^ +1
a TS-9 will knock out some of the low end and tighten up your tone alot.  many players have used this trick over the years.  I don't think an EQ pedal will do what you're after to be honest.
Catalyst77
« Reply #9 on: May 15, 2008, 10:49:48 PM »
I agree, ive tried the mxr 10 band and build a BYOC EQ pedal (which was truly terrible - not sure if that was my fault though!).
but the best thing ive ever used for that is my Keeley SD1
Lazy_McDoesnothing
  • wi, usa
« Reply #10 on: May 16, 2008, 07:10:48 AM »
An over drive is the way to go.  I second what waves said, Drive 0 and play with the tone and volume to where you want.
I hear nothing but good things about the things this guy does:
http://www.bodenhamer-electronics.com/
You can start with one of the overdrives listed and if you want more out of it you can get it modded by someone like him or Keeley etc.
hhcave
« Reply #11 on: May 16, 2008, 08:19:16 AM »
Thank alot guys- i'm taking a look now at the bodenhamer electronics site and i think i'm going to go for one of his modded pedals!
Mesa/Boogie F-50
Marshall TSL 2x12
Stevepage
« Reply #12 on: May 16, 2008, 09:30:00 AM »
You won't regret it. Get the bloody murder if you can!
I done a thread about that pedal not too long ago. Scroll further down this section of the board and you'll see it, has clips too.
Hell Hound
« Reply #13 on: May 16, 2008, 04:15:55 PM »
I use an OD (bloody Murder) in front to tighten my amp, works very well. me settings : level 8, tone wherever it sounds great, gain 2. I set the amp distortion 3 or 4 points lower.
If you don't want to change your amp settings try : level where it equals the bypassed level, tone where you likes it, gain 0
hhcave
« Reply #14 on: May 16, 2008, 05:25:08 PM »
Unfortunately i'm not able to hear the clips using the bloody murder as the intranet i use blocks soundclick - do you have any clips of it which i can download? Or could you send clips to my e-mail? That would be greatly appreciated.
I think i've narrowed it down to the Bloody Murder (BUT i can't stand the paint job...i find it looks quite quite amateur/BYOC-ish), modded Ibanez TS9 or TS808 OR the Maxon OD808
Can anyone please give me some pros and cons for each pedal?
Bear in mind in using it to tighten up my sound/boost distortion a bit for Melodic Death metal/american metal (Dark Tranquility, In Flames, Insomnium, Lamb of God etc.)
Thanks a lot guys!
Mesa/Boogie F-50
Marshall TSL 2x12
