Author Topic: Help on new pickup set for my ES335  (Read 8393 times)
OneFingerSnap
« on: May 18, 2008, 12:16:20 AM »
Hi everyone.
I'm the proud owner of a Gibson ES335. It needed a re-fret, so I decided to take the opportunity to do a bit of a "revolution" on it. I know a pretty good luthier here in Portugal, so for starters, he made me a new ebony fretboard to house the new frets. Also, I wanted to try a set of "rockier" pickups on the guitar. I was curious to hear how a semi-acoustic, jazzier type of guitar would work when used in a rock context. I knew I didn't want a very high gain pickup, I was searching for a middle ground, vintage-like pickup that cleans up nicely and also gets a good distorted tone from a light crunch up to a fairly distorted tone (think Gary Moore, Still Got The Blues). After a bit of research, I bought a Seymour Duncan JB for the bridge and a Seymour Duncan Jazz for the neck.
The problem is I'm not happy with the sound at all, from both pickups. I find it too trebly and harsh, and not meaty enough. I was told the new ebony fretboard also makes the tone brighter, so probably the pickup choice wasn't the best. A friend mentioned he was very happy with the BK pickups he bought for his guitar, so after checking the website, I decided to buy a set of BK's to replace the SD's on my 335.
After reading the pickup descriptions, and the forum, I narrowed my choice down to the Mules, Stormy Mondays or PG's. However, I can't make up my mind between these three! Remember, my original goal still holds; I'd like to use my 335 in a rock context and get both a nice, warm clean tone, up to a fairly distorted, non-harsh tone, definitely more vintage than modern.
One last question: I have a Seymour Duncan Antiquity (neck) in another semi-acoustic guitar, which I am happy with. Which of the BK's would you say is closer to the Antiquity?
Thanks in advance for your help!
PS: Sorry for the boring, long post guys...
Regards,
Miguel
« Reply #1 on: May 18, 2008, 12:26:45 AM »
Have you checked out the Mule demo in the Players section?
For me (probably not helpful) if I had a 335, I would go Stormies. But this is only through imagination of what I think they would sound like. Mules I think might be too overpowering. But the Mule seems to be good for anything.
I would recommend checking out some submitted clips too, here's some:
http://www.bareknucklepickups.co.uk/forum/viewtopic.php?t=3748&highlight=stormy+monday
http://www.bareknucklepickups.co.uk/forum/viewtopic.php?t=3638&highlight=stormy+monday
http://www.bareknucklepickups.co.uk/forum/viewtopic.php?t=4000&highlight=stormy+monday
And specifically this one, as the user actually mentioned it was for classic rock stuff, etc. etc.
http://www.youtube.com/watch?v=C2PX9JWqCTw
Whatever you manage to end up with you won't be disappointed. And welcome too.  :)
Fourth Feline
Re: Help on new pickup set for my ES335
« Reply #2 on: May 18, 2008, 12:28:08 AM »
Quote from: OneFingerSnap
Hi everyone.
After reading the pickup descriptions, and the forum, I narrowed my choice down to the Mules and the Stormy Mondays. However, I can't make up my mind between these two! Remember, my original goal still holds; I'd like to use my 335 in a rock context and get both a nice, warm clean tone, up to a fairly distorted, non-harsh tone.
One last question: I have a Seymour Duncan Antiquity (neck) in another semi-acoustic guitar, which I am happy with. Which of the two BK's would you say is closer to the Antiquity?
Regards,
Miguel
Hi Miguel  :)
Definately the Mules between those two choices for Rock. Also  because I have been trying different pickus in my 335 copy - and whereas I find Alnico II Stormy Mondays to have  a looser, softer, quieter bass definition - a pair of 'Brand x' Alnico V   pickups I tried had a much tighter bass even though they lacked the detail , quality and subtleties of the S.Ms.
For  a 335 ( after some experimentation with my Les Paul, S.G. and 335 copy ) - I would therefore ask Tim for anAlnico IV Stormy Monday set, or in your case. the Mules.
Congratulations on your 335 ownership !  :D
OneFingerSnap
« Reply #3 on: May 18, 2008, 12:49:00 AM »
Wow guys! I wasn't expecting such quick answers!
Thanks a lot, I'll be checking the clips (yet again ;-) You might have noticed that I edited the original post and added the PG's to mix after the first two replies. Sorry about that, I'm still a bit confused as you can see...
I was already a bit more inclined to the Mules, but what if I add the PG's? Between these and the Mules where would you guys go???
Thanks,
Miguel
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #4 on: May 18, 2008, 06:59:46 AM »
I don't have a 335 although I'd love one. I think the Mule would work well but I also think a set of Riff Raffs could be an option, a bit brighter than you were thinking but that's what tone controls are for :)
I see a rainbow rising
Look there on the horizon
And I'm coming home
kellar
« Reply #5 on: May 18, 2008, 10:16:56 AM »
Stormy Monday's are magic in a 335. But, if you want something a little more rock than the Mules are that. What about a Stormy Monday neck/Mule bridge combo? that could be the best of both worlds.
« Reply #6 on: May 18, 2008, 10:23:14 AM »
Apart from the way the neck pickup is wired, I believe the PG Blues set is basically very similar to the SMs.  The SMs aren't really "rock" pickups, unless you're looking no further than a late 60s/early 70s blues-rock kind of tone or maybe thinking of getting a bit jazzy.  Then again, Gary Moore has the PG Blues set apparently, so what do I know?
I don't own any Mules, but I've been reading some good things recently about combining an alnico IV Mule neck with an alnico V Mule bridge.  The AIV neck will be a little tighter than the AII SM, as Fourth Feline has mentioned, but it'll still do nice warm tones.  And the AV bridge will be a little more "rock" again - it apparently has the clarity and bite of the Riff Raff, with a bit of extra meat in the midrange.
« Reply #7 on: May 18, 2008, 12:03:47 PM »
If I wanted to make a rocky 335, I'd go for Riff Raffs, although that might be a little on the bright side with all that maple and an ebony board.
« Reply #8 on: May 18, 2008, 12:18:19 PM »
Quote from: Ratrod
I'm not a 335 owner, but (if my Thinline Tele's anything to judge by) the semi-hollow body seems to bring out the bass and treble more than a solidbody.  I have a feeling Riff Raffs might sound a little "cold" and piercing, especially, as you say, with all that maple and ebony.
Fourth Feline
« Reply #9 on: May 18, 2008, 01:07:11 PM »
Quote from: gingataff
Yes, I was watching the ' You Tube' clip of Larry Carlton playing " Just an excuse" - with his Gibson'57 pickups.  As I listened, I realised that his tone ( towards the end - when it really heats up ) - was perhaps closer to a pair of Riff Raffs I had once heard / played than Stormy Mondays.
As you also observed, you can use the tone controls. Apparently Larry Carlton himself spins his bridge tone control down to about 3-5 sometimes, or as he said " just where bright  starts to become dark ".
My experiments with my 'spare' Gibson pickups seem to re-inforce these observations - although obvously a set of Gibson  490T / 498R  lack the overall qualities of our beloved B.K.P s.
So for me it seemed to prove that Mules and Riff Raffs e.t.c. might be a more viable choice than I had first thought.
Fourth Feline
« Reply #10 on: May 19, 2008, 12:01:07 AM »
I e:mailed Tim - and he recommended that I let the B.K.P team put Alnico IV magnets in my ( now Alnico II ) Stormy Mondays, instead of changing the model of pickups.
Tim said it would tighten the bass - and although I might lose a little warmth overall, the frequency responce would be more even.
All this help / knowledge and he even replied on Sunday !
Great one Tim, thank you .  :D
