Author Topic: HT-dual....mmmm  (Read 2185 times)
  • Truly bad since 1972
HT-dual....mmmm
« on: May 19, 2008, 09:38:20 PM »
Finaly been out tryin pedal's(although guitars got in way)
Ht-distx...(bit too much even though I said wanted high gain)
Chickened out a bit and got the HT-dual...mmmm is sweet
maverickf1jockey
HT-dual....mmmm
« Reply #1 on: May 19, 2008, 09:54:51 PM »
Congrats. I hope you love it.
It took me a couple of days to get it dialed in right (always felt a bit short of treble and the tone controls aren't really all that powerful as far as I can tell) but then I am using it rather unconventionally (as a attenuator + boost and not a boost/eq/Crunch channel + High gain lead channel).
I couldn't really tell much of a difference between the DistX and the Dual when I tested them out.
HT-dual....mmmm
« Reply #2 on: May 19, 2008, 10:04:22 PM »
distx..not as much range
maverickf1jockey
HT-dual....mmmm
« Reply #3 on: May 19, 2008, 10:06:51 PM »
Oh. I hadn't noticed as I'd set up the dual for a quite high-gain boost anyway.
How are you planning on using it?
HT-dual....mmmm
« Reply #4 on: May 19, 2008, 10:09:55 PM »
well have a very clean valve amp single channel, at mo have ch 1 mild crunch and ch2 full on metal...
wish it was earlier..as want to crank it...and it does have amp like qualities
ailean
HT-dual....mmmm
« Reply #5 on: May 20, 2008, 06:38:33 AM »
I really like my HT Dual, if I want to play silent I plug it straight into the E-Mu recording interface, and use headphones on that, sounds as good as an amp :)
A great range of sounds, enjoy!
Gibson LP std + Nailbomb set
HT-dual....mmmm
« Reply #6 on: May 20, 2008, 08:57:14 AM »
Quote from: sgmypod
That's just how I run my Dual.  Into the front of a single channel Orange GRO100.  Sweeeeet!
Mark.
