Author Topic: Cab tolex source  (Read 8637 times)
Oli
Cab tolex source
« on: May 23, 2008, 08:50:09 PM »
Does anyone know of good (and reasonably priced) tolex suppliers that has UK shipping? I'm ideally after some black basketweave, but the only places i can find it, are rather expensive.
I'm covering my open backed 2x12, so i need about 140"x26" worth of tolex (plenty for the cabinet and the rear panel)... it's about time it got covered, has been over a year since i built it!
  • Truly bad since 1972
Cab tolex source
« Reply #1 on: May 23, 2008, 09:00:21 PM »
did you build fom scratch or one of them from ebay(flat pack)
Oli
Cab tolex source
« Reply #2 on: May 24, 2008, 12:16:48 AM »
Quote from: sgmypod
Built it from scratch- took rough measurements from my Marshall 1936, but it's slightly shorter, wider and a little bit deeper (and open backed, which the 1936 isn't). I've got a big 24 track recording assignment coming up in the next couple of months, and i'm going to be using this cab for recording rather than the Marshall- it sounds much better all round i think. I'm probably going to build another one sometime in the summer, it should be even better :)
Cab tolex source
« Reply #3 on: May 24, 2008, 12:32:07 AM »
I still have a fairly good stash of Marshall black tolex left over from when i made the huge fake speaker cabinet that housed the flatscreen that I used at the London Guitar show
Cab tolex source
« Reply #4 on: May 24, 2008, 01:58:54 AM »
Quote from: FELINEGUITARS
i so need that for my front room -- first i need a new tv though... one that doesnt buzz when the screen is bright :?
it might have to be red levant or oxblood.... thats the way i managed to get my amp into a living room - it matches the chimney breast :wink:
Woogie
Cab tolex source
« Reply #5 on: May 24, 2008, 11:23:00 AM »
Excess audio on ebay ;)
Cab tolex source
« Reply #6 on: May 24, 2008, 11:36:46 AM »
Sorry to hijack slightly.....how easy is tolexing a cab...and what glue etc do you use
Woogie
Cab tolex source
« Reply #7 on: May 24, 2008, 12:24:21 PM »
Quote from: sgmypod
YOu have to cover the cab once to get the tolex stretched right and then you do it again and stick it down. Not sure which glue though.
Cab tolex source
« Reply #8 on: May 24, 2008, 12:40:30 PM »
In a similar manner, where do you get speaker grille cloth from? All the places I've seen want about 20 quid for enough to cover a 4x12 cab, which seems pretty expensive to me (or am I just being a miserly bugger?)?
Cheers in advance!
Roo
Woogie
Cab tolex source
« Reply #9 on: May 24, 2008, 12:48:58 PM »
Quote from: Roobubba
Cheers in advance!
Roo
Excess audio again
Cab tolex source
« Reply #10 on: May 24, 2008, 01:51:38 PM »
I just call Matamp and ask if they'll sell me some - they're always very accomodating.
Even better (if you fancy a drive out) is getting Matamp to recover or re-grille the cab for you.  It's breathtaking watching Jeff at work and noting how quick and accurate the guy is at this stuff.
Cab tolex source
« Reply #11 on: May 24, 2008, 02:02:09 PM »
what's he charge for recovering
