Author Topic: Guitar hangers:  (Read 3549 times)
Guitar hangers:
« on: May 26, 2008, 01:33:46 PM »
Does anyone know why this says, not suitable for guitars with Nitro laquers?
http://www.thomann.de/gb/hercules_stands_gsp39wb_guitar_wallmount.htm
All of the wall stands on the Thomann site says it :s
Reorganising my room and want some guitar hangers, does anybody have something like this:
http://www.thomann.de/gb/km_16295.htm
They look so damn cool, but is it secure enough with those 4 screws?
Guitar hangers:
« Reply #1 on: May 26, 2008, 01:36:17 PM »
Rubber type stuff burns through Nitro finishes, is not pretty
http://www.box.net/files#0:f:15415517:1:f_161812474
Guitar hangers:
« Reply #2 on: May 26, 2008, 01:41:29 PM »
Probably because  it has some sort of rubber padding and rubber is always in a state of disintegration giving off sulphur gas
The sulphur melts nitro finishes making a real mess
I have seen this on so many Gibsons that it is almost unfunny
I owned a Les Paul that very quickly got marks in the finish from a stand
Some shops wrap silk or dusters around the rubber bits on stands
Quote
Nitro is way overrated in many ways IMO, even though I do like it
So often you see people posting about it because they have seen others post about it in vintage vs modern guitar discussions and they just quote verbatim  what others have said without their own insight & research/experimentation into it
Guitar hangers:
« Reply #3 on: May 26, 2008, 01:46:25 PM »
I don't think any of my guitars have a nitro finish... But please correct me if I'm wrong...
Ibanez RG42DXFM
ESP Horizon
ESP Viper Camp (some sort of satin finish)
Epiphone SG G400 Custom
Dean Exotica FM Acoustic
Warwick Rockbass Corvette
  • Truly bad since 1972
Guitar hangers:
« Reply #4 on: May 26, 2008, 02:03:24 PM »
what about the quik lok stuff
Stevepage
Guitar hangers:
« Reply #5 on: May 26, 2008, 02:13:45 PM »
No none of those guitars have nitro finishes. I used to use them for some of my guitars and never had a problem with them. I only took them down because I prefer to keep them in their cases out of the way of people.
tomjackson
Re: Guitar hangers:
« Reply #6 on: May 26, 2008, 09:53:01 PM »
Quote from: noodleplugerine
4 screws would be fine, is the wall brick or plasterboard?  As long as the correct size drill bit is used for the raw plugs it would be fine.  If its plasterboard over brick make sure you go into the brick also, there will be a gap in between the two, just make sure some brick/mortar dust appears on your drill bit.
Stud walls would require plaster plugs but should still be fine.
Re: Guitar hangers:
« Reply #7 on: May 26, 2008, 10:03:35 PM »
Quote from: tomjackson
It'll go into one of my brick walls, cheers for the help dude. Will be going down the road and buying some tommorow methinks.
Fikealox
Guitar hangers:
« Reply #8 on: May 26, 2008, 11:56:29 PM »
How do you guys think the Hercules hanger would go with an asymmetrical strat-type headstock? Do you think it'd be a problem? :-\
BKPs (soon): CS, TS.
Guitar hangers:
« Reply #9 on: May 27, 2008, 01:42:16 AM »
Quote from: Fikealox
No problem - they swivel !
