Main Menu
Pickups?
Started by Horlicks, May 30, 2008, 08:49:11 PM
Quote from: Horlicks
Quote from: RoobubbaThat cold sweat that Tim suggested should suit you down to the ground for the neck, I would think. But don't take my word for it ;)
(I'd take Tim's suggestions as they are, the man knows more than I can possibly imagine when it comes to this stuff!)
QuoteThe neck pickup is where this set really disapoints, its really really poor. It just sound like a wooly mess, no clarity or string definition what so ever. The low output is really evident here, it doesnt even match the bridge pickup (before you ask, Yes i had them installed proffesionally, by no other than Mansons). To be honest you might as well not even have a neck pickup if its as poor as this.
Where is that from?
Doesnt sound like any BKP I've ever played.
If its about the CS neck: it couldnt be further from my experience. It has a really chiming, piano-like clean and a tonne of sting definition under high gain.
Antag
Quote from: MDV
Where is that from?
+1
Regarding Roobubba's comment about the Cold Sweat neck, I presume Tim's recommendation was for the CS bridge and Stormy Monday neck.
It's the SM that's going to give you those Slash neck sounds, so that review of the CS neck, accurate or inaccurate, is kind of irrelevant.
Horlicks
*looks at his amp*
*sees Line 6 Spider and Marshall AVT*
:roll:
^ Will stormy monday do shred though?
Gear
Washburn X50-Pro
Ibanez SA120
Laney VH100R
Laney VC15
Maxon OD808
ISP Decimator
Yeah I'm with MDV^^ I don't know where that second quote has come from, but that's completely the opposite of everything I hear about the CS here and elsewhere!
if you're confused about my post, perhaps you could specify what it is you'd like me to clarify?
Roo
Ahhh I see Philly, yes that would make a lot more sense!!
In which case, I'm wrong (as usual!) and you should go with the Stormy Monday neck :)
I was, however, right about one thing: Tim does indeed know infinitely more about this stuff than me :D
Roo
Horlicks
What about the crawler?
Gear
Washburn X50-Pro
Ibanez SA120
Laney VH100R
Laney VC15
Maxon OD808
ISP Decimator
Doog
Quote from: HorlicksI'm still thinking of the nailbomb because it's meant to be really warm and my amp is too bright ATM. Neck pup still undecided, what has great cleans and can do Vai style gain and tones?
not sure about the nailbomb being warm myself... in my experience it's quite a bright pickup.  if warmth is what you're going for then perhaps the holydiver would be a better choice?
oh and what everyone else said about the cold sweat neck, the one I've got is utterly brilliant
nailbomb & stormy monday; holydiver pair; cold sweat pair
Horlicks
Quote from: Doog
Thanks for the comment, at the moment i'm veering towards a cold sweat neck because they seem so versatile and I normally use coil-split for cleans.
For the bridge I'm looking at Cold Sweat, Crawler, Nailbomb...
Gear
Washburn X50-Pro
Ibanez SA120
Laney VH100R
Laney VC15
Maxon OD808
ISP Decimator
ilÿti
Cold Sweat neck would be a good choice to come close to both Slash and Vai tones, as would Abraxas or Crawler. For the bridge you haven't really mentioned specific tones, but if your amp is too bright for your liking, better error on the side of warm than the side of bright don't you think?. Cold Sweat and Nailbomb have a definite edge to them that could be perceived as birght. Holy Diver I'd say.
Crawlers, Mule-7s
The CS neck will get you a lot closer to vai than slash (dissimilar sounds).
Perhaps you could get slash out of it with the tone rolled back? I havent tried it, though, just an idea.
Holy diver, by my understanding of its reputation, wouldnt be a bad choice. I wouldnt call the nailbombs bright though: they dont have that much treble, but rather an open crunch in the high mids. Depends what part of the spectrum youre calling bright, I suppose.
You couldnt go far wrong for what you want with a crawler set, either.
ilÿti
Quote from: MDVYou couldnt go far wrong for what you want with a crawler set, either.
Agreed with a but.
The middle position is definitely not for everyone.
Crawlers, Mule-7s
I got on well with it (when I had crawlers), but I can see where youre coming from there.
Quote from: ilyti
Agreed with a but.
Any chance you could describe why? Sounds interesting
Quote from: Will
Quote from: ilyti
Agreed with a but.
I'm interested too.  I've got mine wired out of phase, so I don't really know what the normal in-phase sound is like.
