Main Menu
Pickups?
Started by Horlicks, May 30, 2008, 08:49:11 PM
Crawler. Its the safer bet, IMO, provided youre ready for its mids.
Horlicks
Quote from: MDVCrawler. Its the safer bet, IMO, provided youre ready for its mids.
I love mids  :)
Gear
Washburn X50-Pro
Ibanez SA120
Laney VH100R
Laney VC15
Maxon OD808
ISP Decimator
Get a crawler  8)
Quote from: Horlicks
I love mids  :)
It's got more mids than a very very middy thing.
Horlicks
Are the low-mids or high-mids?
Gear
Washburn X50-Pro
Ibanez SA120
Laney VH100R
Laney VC15
Maxon OD808
ISP Decimator
Both, but more mid-mids and high-mids.
Horlicks
Anything warmer?
Gear
Washburn X50-Pro
Ibanez SA120
Laney VH100R
Laney VC15
Maxon OD808
ISP Decimator
Holy diver?
Going round in circles now though.
Horlicks
OK, I will go for crawler bridge, last question crawler set or cold sweat neck?
Gear
Washburn X50-Pro
Ibanez SA120
Laney VH100R
Laney VC15
Maxon OD808
ISP Decimator
ilÿti
Quote from: HorlicksOK, I will go for crawler bridge, last question crawler set or cold sweat neck?
Did you read my post about the Crawler set? If you want the big clunk in the mid position get the set, if not, get a Cold Sweat neck with a Crawler bridge.
Crawlers, Mule-7s
Horlicks
Well, I never use the midle position, so I'm still undecided
Gear
Washburn X50-Pro
Ibanez SA120
Laney VH100R
Laney VC15
Maxon OD808
ISP Decimator
Quick refresh then:
What do you want from the neck?
CS will give chiming cleans and clear, liquid lead.
Crawler will give much warmer, smoother cleans and overdriven is more classic rock, gritty blues.
From your clips, I'd say CS. But none of them were clean....
Horlicks
Gear
Washburn X50-Pro
Ibanez SA120
Laney VH100R
Laney VC15
Maxon OD808
ISP Decimator
best check with tim to make sure the crawler/CS set will work in your guitar. just to be safe. :)
EDIT: regarding mid-output pickups in mahogany, i thought it was alnico you wanted to avoid as well? the CS bridge is ceramic, so maybe that's why it works ok?
