Author Topic: guitar maintenance  (Read 4488 times)
JDC
guitar maintenance
« on: May 30, 2008, 09:29:16 PM »
I've had my guitar for 2 and a half years now, and I need to get some new string so I thought, what better time to find out what else I should get, I don't look after it as well as I used to and it needs a good sorting out
the main concerns are:
does the neck look dry, aka does it need that "lemon oil" stuff or is it just dirt?
and what's the best way to get rid of the dirt
should I do anything about the back of the neck or leave it?
any other recommendations?
hamfist
guitar maintenance
« Reply #1 on: May 30, 2008, 09:44:46 PM »
Seriously, have you had the same strings for 2 & 1/2 years ?
hamfist
guitar maintenance
« Reply #2 on: May 30, 2008, 09:45:56 PM »
  • Truly bad since 1972
guitar maintenance
« Reply #3 on: May 30, 2008, 10:32:22 PM »
Yeah would change strings a bit more often or buy elixirs...frets look to have a bit of wear and yeah would lemon oil the fretboard9mine want that bad but took of dirt when applying and wiping of excess
JDC
guitar maintenance
« Reply #4 on: May 31, 2008, 01:24:59 AM »
Quote from: hamfist
been busy and not got round to it, I mean to change them every 2 months
they are 3, maybe 4 months old, hardly had chance to play on them when they were new :(
guitar maintenance
« Reply #5 on: May 31, 2008, 02:13:46 AM »
lemon oil isnt needed yet, under the grime teh board looks to be well hydrated - thats just grime and needs removing 0000 liberon wire wool from axminster will do the trick... might even break out the trimmed down toothbush for this.... naptha (lighter fluid (note the word fluid.... fluid =liquid... not aerosol gas) will help with cleaning tough grime)
you should definately consider a fret dress as well as changing your strings more often!!!
anyway, wire wool
http://www.axminster.co.uk/product-Liberon-Steel-Wool-23679.htm
JDC
guitar maintenance
« Reply #6 on: May 31, 2008, 04:31:28 PM »
thanks wezv, your the man
anything I can do make the back of the neck more slidey?
guitar maintenance
« Reply #7 on: May 31, 2008, 04:33:39 PM »
that wire wool is good for slightly taking the gloss off the finish
i should give the usual warning about masking off pickups before using the wrie wool... just as a precaution
guitar maintenance
« Reply #8 on: May 31, 2008, 04:51:38 PM »
well definately giveit a rub done with the wire wool first to clean it up
then might be worth giving it a few coats of tru- oil followed by anothe rub down a few days later.
thats how jonathan does his oiled neck and its working well for me since i finally got around to buying some tru-oil - so we can thank jonathan for that one
the tru-oil is just quicker and esier than the oils i was using before but the results are similar
