Author Topic: HELP!! Midi keyboard setup with cubase  (Read 4010 times)
silentrage
« on: June 07, 2008, 03:00:22 PM »
If you know how to do this, pleaaaaaase give me a hand, it's really starting to piss me off.
I bought a midi to USB adaptor and thought I'd plug my casio ct-640 into my computer and use it as a midi controller, but I was wroooooooooooooong.
Cubase refuses to let me set the keyboard as midi input, it only lets me set it as an OUTPUT source @_@
here's what I did:
plug IN cable to OUT port on keyboard
plug OUT cable to IN port on keyboard
plug USB end of cable into computer
windows recognizes this as "USB AUDIO DEVICE (2)"
but it doesn't show up under the midi input device list in cubase
  • Truly bad since 1972
« Reply #1 on: June 07, 2008, 03:30:30 PM »
is it set to send and recieve midi on the keyboard itself
silentrage
« Reply #2 on: June 07, 2008, 05:42:07 PM »
yes, I put it on midi mode.
« Reply #3 on: June 07, 2008, 05:49:06 PM »
whats the midi device
silentrage
« Reply #4 on: June 07, 2008, 05:53:28 PM »
it's a casio ct-640 synthesizer,
if you mean my audio interface, I don't have one, just an onboard soundcard.
« Reply #5 on: June 07, 2008, 05:54:34 PM »
nah meant the midi to usb
silentrage
« Reply #6 on: June 08, 2008, 07:07:59 AM »
it's just a generic noname midi to usb adapter,
it's got 2 cables that are midi in and out, leading to a box with 3 leds on it, and that goes to a USB connector.
« Reply #7 on: June 08, 2008, 10:41:23 AM »
hate to ask but is it full duplex or in drivers section of windows does it say full duplex or two way communication..for the usb to midi box
silentrage
« Reply #8 on: June 09, 2008, 08:15:18 AM »
no prob,
I checked all over the drivers section for the usb audio device(in the control panel > device manager), couldn't find anything that resembles "full duplex" or "two way communication".
Where should I be looking?
but I do know that I'm using the ASIO4ALL driver for my asio.
Does that help?
« Reply #9 on: June 09, 2008, 08:48:21 AM »
in drivers under sound, video drivers should be the midi driver.
If that doesn't work try http://www.borg.com/~jglatt/progs/software.htm
first download and run genmidi.dll and midifile.dll..then midiinputviewer
open the midi input viewer(with keyboard on and connected midi) select under input your midi source and same with output then press any key on keyboard and see if a load of numbers come up to tell you you have communication.
Also on there is a prog called midi info, which tells you what channels etc and what equipment you have connected
Checking these things will tell if its keyboard or cubase
silentrage
« Reply #10 on: June 11, 2008, 09:28:32 AM »
ok I tried MIDI input viewer, the "USB audio device" shows up under both input and output of the program, but I tried playing a bunch of notes, putting the keyboard in all different kinds of modes, switching the cables around, etc etc, and nothing shows up in the MIDI viewer window whatsoever,
so I assume either the interface or the keyboard is at fault?
« Reply #11 on: June 11, 2008, 10:26:12 AM »
Would seem that way, was why asked to do that test..was to take cubase..which can have it's own problems out of the equation.
Is there any keyboard shops near you? or a friend who has a comp with midi that you know works
