Author Topic: weird problem  (Read 3780 times)
shaman
weird problem
« on: June 10, 2008, 12:38:45 PM »
well, I installed a Mule into the bridge position of a Jackson PC-1-sounds terrific,but I noticed as I was playing yesterday that when a string touched a pole piece,the sound cut out totally....I suppose its some type of grounding issue, but there is no hum/buzz/etc...I pulled out the pup and did all of the basic trouble shooting...can't figure this one out -
seems like someone had a similar post recently..searched and could not find anything
any ideas? thanks!
shaman
weird problem
« Reply #1 on: June 13, 2008, 12:42:02 AM »
bump....anyone??/maybe I will post in pickup section...
weird problem
« Reply #2 on: June 13, 2008, 10:24:25 AM »
When a string touches a polepiece, it stops vibrating.
The strings should never touch the pickup in any way. Lower your pickups.
weird problem
« Reply #3 on: June 13, 2008, 01:05:44 PM »
I agree with Ratrod fully, you need to do this anyway.
BUT, if you are saying that the signal cuts completely when the string touches the polepiece - then I'm not convinced that's right. I'm also not convinced the problem (if there is one) is outside of the pickup itself.
As far as I'm aware, the polepieces shouldn't be part of the electrical circuit. If a string (which should be earthed, via the bridge assembly usually), just by touching the polepiece, causes the pickup to short out, then I think something's funny.
Conceivably the the other end of the polepiece screw (underside, in the cavity) is somehow touching a bare hot wire from the pickup? Then the string would short the hot wire to ground because it complets a circuit when it touches the top of the polepiece?
Otherwise, I would start thinking there's some kind of short inside the pickup? and therefore you might not be getting it's full glorious tone anyway?
Techies help me out here - I'm making this up as I go along!  :roll: I could be completely wrong here (my strings never touch polepieces, maybe it does cut out anyway!)
Failing that I'd suggest emailing Tim and see what he thinks - I'm sure he'd be keen that not only do you get the best out of it, but that you're sure you're getting the best out of it.
Hope that helps.
shaman
weird problem
« Reply #4 on: June 13, 2008, 03:13:20 PM »
thanks guys-the height is not the problem-I really dig in(a lot of hybrid picking) and sometimes the strings do touch the pole piece,esp. in a strat style guitar-my other electrics(7 of em..) do NOT do this-might get a cool puckering sound, but this is acting like an on/off switch-also, a dive bomb via the floyd...I like to kill the string out on the pup from time to time(when I feel Van Halen-ish...)-also, the PC-1 has two other pups...they react normally when the string touches them-lowering the pup,therefore,doesn't correct the problem-it would only sidestep it,and thenthe tone suffers
thanks for replies,and keep em comin'!
weird problem
« Reply #5 on: June 13, 2008, 04:04:03 PM »
My gut feeling is something's wrong then...
Hopefully someone has come across this before, otherwise, I'm sure Tim would be happy/able to give you an answer.
