Given the choice, a 1x12 or a 2x10?
Started by gamesandy135, June 23, 2008, 05:25:22 PM
tomjackson
I'd go for the 2x10.  You already have a 1x12 in the amp so this would give you the best of both worlds and open up options for recording.  You could mic a 12inch and a 10inch and then chose the best one at mixdown, or blend them.
And the 2x10 configuration does not have less bass, it's just that the low end is raised slightly , say (total guess) 15hz higher.  I find that this adds more high bass/low mid punch.  Also, smaller coils have a quicker response and hence quicker attack.
I used to have the Laney mini stack like this, the extension cabs are the same size anyway so you won't be able to tell whether there's 2x10 or 1x12 inside.
If I was going for just the combo I'd say 1x12 although the Vibroverb 2x10's are sweet amps
shaman
here is what one Thiele 1x12 leads to!!.....check out the ease and versatility of such a set up....a head and a Thiele is sooo easy on the back-paired with a combo is killer as well-we can take 1 cab,2 cabs,etc...sound is huge!!!(of course, these are all loaded with EVm 12L speakers-a load,indeed....)
I'm now a big fan of muxing speaker sizes in a rig, I've got a 4 x 12 and another 4 speaker cab containing 2 8" speakers and 2 15" speakers.
I'd say go for the 2 x 10", as the breadth of acoustic options this gives you will be really nice, IMHO :)
Roo
Pete24v
I had the same 2x10" cab, i prefered it over the 1x12, seemed to give a bit more of everything. could've been down to the speaker though..
shaman
Quote from: sgmypodI now have gas for shaman setup
thanks- 8)
you should see the wood in person...almost 3 dimensional-they do incredible work in their custom shop
the ported Thieles are massive sounding-must be heard to believe
yeah pretty and bet they sound good as well..is one for stage(black) and one for home
gamesandy135
Thanks for all the advice guys.
I see that opinion is really mixed and down to taste.
I was all but set on the 1x12 but now I'm not so sure.  I was going to get it and change the speaker for the Celestion K-100 as I've heard so many good things about it.
Don't suppose there is an equivalent 10" speaker?
I looked on their site (Celestion) and seen a "Tube 10" speaker that seems roughly in line with a K-100.
That said, I'm discounting other speaker manufacturers of which I have very limited experience.
Ahh, well you didn't say you'd change it for a K-100... I'm going to change my mind from a 2 x 10 to a 1 x 12 in that case :)
Roo
shaman
Quote from: sgmypodyeah pretty and bet they sound good as well..is one for stage(black) and one for home
indeed!!!the wood is insured by 2 pitbulls and a Smith and Wesson .44 mag, and never leaves the house!!
