Author Topic: Pig-90?  (Read 3676 times)
Jay
Pig-90?
« on: July 09, 2008, 09:17:47 AM »
I need a P-90 for an LP Junior. I mostly play rock and metal (thrash, death, etc.) and I'm after raw and noisy overdriven/distorted tone as well as a decent clean tone.
I'm pretty sure the Pig-90 is quite capable of the raw and noisy part, but how does it handle cleans? I don't want them to be crystal clear but I'd like a pickup that can do a little more than scream its pole pieces off . :wink:
So, will the Pig-90 meet my needs or will I have to look at the P-90/91/92?
Thanks for any help.
Re: Pig-90?
« Reply #1 on: July 09, 2008, 09:25:17 AM »
You could get a Pig-90 with a coil tap - this would lower the output a bit for your clean tones?  You'd need a push/pull pot fitting to your guitar though, the usual one to replace is the tone pot.  Quite a simple mod  :D
Jay
Re: Pig-90?
« Reply #2 on: July 09, 2008, 10:49:48 AM »
How do coil taps sound on P-90s? I don't know too much about the P-90 design but I'm not a big fan of coil taps on humbuckers.
Re: Pig-90?
« Reply #3 on: July 09, 2008, 10:56:28 AM »
Humbuckers have coil SPLITS, where you have one coil (not both) active.
My old MQ had a tap, which basically lets you use less coil winding of the pickup for output.  It works pretty well to give a cleaner, thinner sound.  I think is what you're looking for.
Re: Pig-90?
« Reply #4 on: July 09, 2008, 11:45:47 AM »
Just to be a pedant
Humbuckers can also have taps. SCs cant have splits (obviously).
Re: Pig-90?
« Reply #5 on: July 09, 2008, 11:53:59 AM »
Yeah, I know humbuckers can have taps but it's highly unusual.  I'm not sure BKP offer that facility?
Re: Pig-90?
« Reply #6 on: July 09, 2008, 11:58:15 AM »
I have a sneaky feeling they do. Not sure though.
Jay
Re: Pig-90?
« Reply #7 on: July 09, 2008, 01:46:21 PM »
Ah, thanks for the clarification. It looks like the Pig-90 is the way to go then.
Thanks for the help.
everton_fc
    • Guitar Jar
Re: Pig-90?
« Reply #8 on: July 10, 2008, 01:51:44 PM »
what's a pig-90?
Re: Pig-90?
« Reply #9 on: July 10, 2008, 01:57:14 PM »
What it says on the tin - a p90 with a pig wind. Its in between a warpig and a sinner.
Re: Pig-90?
« Reply #11 on: July 11, 2008, 08:22:48 PM »
I emailed tim about the pig90 recently because I cant decide between a bridge MQ or Pig 90 and he said:
"Yes we can make you a humbucker sized Pig90 and it'd sound monstrous in an all mahogany LP.Totally different beast to a stock MQ-way more power, thicker saturated tone."
"It's the same power as a Sinner but with even more bottom end chunk-I can build them with ceramic mags for eben tighter bass."
Sounds good! I cant decide whether to get one or a standard p90 though - I dont really know what sound I'm after :?
edit - Ordered a bridge Pig 90 today :D Allready cant wait for it to arrive so I can put it in (If I manage to figure out the coil tap :P)
« Last Edit: July 13, 2008, 02:49:01 AM by _tom_ »
