Accurate Pedal Tuners
Started by BigK, July 09, 2008, 06:52:05 PM
Which should I go for?
Peterson Strobo Stomp 2
4 (40%)
Korg Pitchblack Plus
2 (20%)
Other
4 (40%)
Total Members Voted: 10
BigK
Im just looking for some advice on which tuner to get. I want something that is very accurate (ive basically become my bands Tech and re-stringing and doing some setup work for a local shop. And I'm in the market for a very accurate tuner for use not only during setup (inotation etc) but also Live as a stompbox. So far Ive come up with the two above but other options are welcome.
So far I like the look of the look of the Pitchblack plus, but is the extra £50 of the strobostomp worth the money? so far the only real differences is that the strobo stomp has those 'sweetened' tunings and a buzz felten mode (none of the guitars I own or work on have this).
Any thoughts would be most welcome.
PRS Tremonti - PRS Silverburst 594 - Ibanez RG550EX, RG570 & RG721FM - LTD SC 500 -  Schecter 006's - EVH 5150III 50w into custom Zilla Vert 2x12
cnotold
i just love peterson product. I've never believed in the hype of this thing but once i've started using it, i couldn;t go back to any other tuners. i just feel very secured with strobostomp and isn't it what it's all about?  :)
i havnt tried the pitchblack but i have been nothing but impressed with my peterson stroboflip... the stomp is essentially the same tuner in a pedal - no less accurate anyway.
BigK
sounds like its goin to be the strobo stomp unless anyone else has any other choices...
samoth2
http://turbo-tuner.com/pages/manual-st2.htm
This might be worth a look. No personal experience with it.
Fikealox
I haven't used the pitchblack plus, but I have the pitchblack, and it's an excellent tuner. Very accurate, easy to use, and super-convenient (it mutes output when it's in use, and is TB when it isn't). The only problem I've had is a problem I've had with any electronic tuner, which is the tuner getting confused by an abundance of overtones. That's easy to get around though :)
BKPs (soon): CS, TS.
JJretroTONEGOD
Quote from: Fikealox on July 10, 2008, 12:15:53 AM
just dont put it in a valve powerd effects loop lol
Dazza1004
I have a peterson and I can only say good things about it.
Now I get stuck tuning everyone else's guitars though, even the sodding bass
Simon D
The Planet Waves CT 04 chromatic pedal tuner is worth a look. Nice big, clear readout for dark stages, and it's hard bypass. Costs a bit less than the Peterson too. Not quite so feature-loaded, but i've got no complaints about mine.  Best price I could find was here:  http://www.soundslive.co.uk/product.asp?id=5243
Warpigs.
hhcave
I got the Korg DT-10 which is pretty accurate - i chose it over the peterson because the peterson took so long to use that it would probably (i may be wrong!) be impractical in live situations... Th Korg i was told is one of the fastest to use out there
Gisbon Les Paul Custom with MMs
Bodenhamer modded Maxon OD808
Mesa/Boogie F-50
Marshall TSL 2x12
ToonLP
Peterson Strobostomp is amazing. When you think you're tuned with a "normal" chromatic such as Boss TU-2 etc, plug into a strobostomp and you'll find you aren't. Buy once, will last a lifetime.
I am not young enough to know everything
LP R9 VOS with Mules
Marshall 2061X head with 2061CX cab
