Still wondering...
Started by puma_21, July 10, 2008, 10:05:00 PM
puma_21
Is the Ceramic Warpig only 18k?
How would this sound at 23K?
If the MM is overwound to 23k: how would that sound in comparison to the C-Pig at 18k and at 23k?
I'm mainly interested in the tonal differences and applications for the two. I'm pretty sure either of these is what I want.
I'm one of those dudes who uses EMG's (and hopefully will be one who used to use EMG's). I've been listening to a ton of clips and I'm still very uncertain of which direction to go.
ilÿti
Bear in mind that the dc ratings don't say much about the sound of the pickup, and varies a lot within the same model. There has been C-Pig rating upwards of 24k. As for the tonal differences, I wonder too. But I'm sure MDV will help you out.
Crawlers, Mule-7s
You also have to take into account the offset wind I think Tim used in the crazy MM
Bear in mind the 23k MM is a one-off that I had made for me, and its double screw pole, so its got more low end than a normal MM too.
The principle differences you get from overwinding a pickup are more output (duh), more compression and, all things being equal, less high end (Tim compensates for this, however).
The C-Pig is about 21 to 22k, not 18.
The Monster Miracle Man, as I like to call it, has a little more output than a C-Pig. Its noticable easily A/Bing, but play one a couple of days after the other and you arent really concious of it. Similar story with the 81. They are all in the same ball park.
The most stark difference between the most powerfull BKs (mine, BWAHAHAHAHAHAH...ahem, carrying on) and EMGs and the 81 especially (which I assume is your reference due to its ubiquity) is the compression. EMGs are way, way compressed. The BKs, not so much. The low 20k bks seem to have a similar level of compression to most pickup makers mid-high teen DC pickups. Just devastating amounts of gain.
Also, the EQing of the top output BKs is different, both between themselves and from EMGs. The most similar BK EQ wise to an 81 is the painkiller, because of its prominent high midrange, but its less powerfull (not by much mind) and much less compressed.
If you want an 81-alike BK then I suggest a painkiller wound to perhaps 18 or 19k (obviously Tim is the authority on what to wind it up to, and dont forget its got 3 big ceramic magnets in it: it doesnt need to be wound as hot. Its not very far behind a C-Pig in outpt at 6 or 7 ohms lower DC!). Its still not going to be very much like it though. Painkillers are far more lively than 81s, and have wa more low end. In fact, all the bridge BKs I've tried have way more low end than the 81 (and in the case of the ceramics, equally tight if not tighter (the painkiller is the tightest)).
Of the stock or regularly ordered variations, the C-pig is your pickup.
Oh, and Will, I dont know what offset the MMM has, so I'd be very curious to know how you know! (a normal MM has about 500 turns of offset, I believe, and all BK humbuckers have it, but I dont know if mine is any more).
puma_21
Jeez... you guys are SO damn helpful!
Sometimes I wish I weren't so picky. Most of the time, my indecisiveness tends to cause me to become even more confused with what I really want. And, I always get huge buyer remorse. Blah!
I know, that I don't want EMG's. I'm looking for something not with EMG sound, but rather the same characteristics as the in your face, high gain, and sharp attack. I read somewhere on this forum where someone described them sounding like "toy laser guns" LOL. I must say that is the most accurate description of those cr@p pickups.
Does anyone have a comparison between a C-Pig and PK doing some metal with the same amp/guitar (pref. Mahagony). I know that they are voiced very different and that the C-Pig has more gain and compression, but still retain their organic qualities (which I am so anxious to finally play). I'm simply wondering, now, what the tonal differences between the two are.
I'll leave another example of a metal band that I currently listen to. I like their tone--I can't help it,. It is, sort of, the voicing I'm going for, BUT way better. Their solo on dead divine's tone is the sort of lead solo tone I like too. I also love Racer X.
http://www.myspace.com/anterior
Thank you, again, for answering my questions, and so quickly, too! You know your sh*t MDV!
Quote from: MDV on July 11, 2008, 07:44:05 PM
I seem to 'remember' Tim adding on to something you said at one point, and that the MMM was only possible to retain the sound of the MM by an offset.
but my memory isn't what it used to be...
#7
i don't think you'll need any overwound model
i had EMG's and other monster output pickups, like gibson 500t and mighty mite motherbucker, all in the same guitar
the miracle man and the painkiller have enough output to substitute EMG's in a way you won't miss ANYTHING
and I disagree about the painkiller being eq'ed closer to the EMG 81
it has a ton more mids and the highs are rawer (in a good way)
the EMG 81 has a strong bass, but lacks low-center mids
the miracle man is closer, with sharper treble and a bit more precise highs, but still have more low mids than the EMG 81
both have more output than duncan custom, distortion and dimebucker (most people that change back from actives to passives, get one of these models at first)
ps: note that i'm talking about the EMG 81 only
the 85 has a totally different EQ and a ton more output
Will - one sees! Cheers
Eric - the 81 has very little bass. What have you been playing it through? The miracle man isnt closer. Like I've said before, Ive had an 81 and a miracle man (actually, 3 different miracle men!!) in the same guitar, and the MM has WAY more lows, and less mids and high mids. It also lags behind it slightly in output. Please dont try and tell me that it doesnt, when I have extensively A/B'd the standard 17k MM with the pig and 81 and discovered it to be noticably lower in output, and a 23k MM and discovered that to be very similar output to the Pig, 81, and c-pig.
Puma, you happen to be a lucky fussy git.
I just happen to have exchanged the C-Pig/ Cold sweat combo in my Legra yesterday. Then put the CP/CS back in. Then the PKs back in. Then the CS back in. A/Bing with the Monster Miracle Man and A5 warpig at each stage.
My conclusions:
Most obviously, I am a little wrong about the PK output. It could stand to be the tiniest shade more powerfull to hang with the big boys, but you only notice it in A/B ing. Play an 81 one day and a PK 2 days later, and you wont notice the gain difference.
This changes nothing about the gain levels of the miracle man. If my conclusions were different then I wouldnt have a 23k miracle man (oh, Tim chose the output, I just asked him to make it as powerfull as possible while still sounding baislcally like a miracle man) and I would have an overwound PK!
The painkiller is the tightest BK. Or at least of all the ones I've played; excluding singles, 5-Pig, C-Pig, NB set, PK set, CS neck, Crawler set, MM, Double screw pole MM, 23k double screw pole MM (of those I havent the Cold Sweat bridge might be tighter< I suppose, but I cant imagine a tighter pickup).
It has a very full and not-in-the-slightest-raw high end (sorry eric, I [/i]strongly[/i] dissagree with that - perhaps you should have changed your strings if you played it). This is especially true compared to the others, where due to the compression, the highs get a little squashed in and are comparatively thin and scratchy (note, that is COMPARATIVELY, as in to a painkiller. they still make the vast majority of similar output pickups sound like the thin and scratchy ones).
C-Pig Vs PK.
Bear in mind my PK is double allen bolt, and covered, and the C-pig covered and double screw blot. That means that both have the tiniest highs attenuation, but the PK, with steel allens, is a little brighter that the iron screws, and the standard PK is single screw pole, so I've got about 15 or 20%-ish more low end from mine.
The C-Pig is hotter, no doubt about it. But I'd be very, very suprised if the PK wasnt hot enough for you.
The PK is tighter.
The PK is louder. Probably the mids being heard more easily by the ears.
EQing - If I arbirarily set the C-Pig at 5/5/5/5/5, bass, low mids, mids, high mids, treble then the PK is something like 4.5/6/6/7/5
I'm not going to guess what a single-screw pole would be.
The PK has a more dynamic response.
The PK is quite a ways better to shred on. It makes lead sound BIG. Which is....errr.....odd, but very cool.
All told, I left the Painkillers in and have no desire to move them. Asside from anything else the PK neck is one of the finest pickups ever created.
Oh, and, Eric,
The output characteristics of an 81 and 85 are elctrically identicle. They have exactly the same output
RMS voltage - 1.25
Peak V - 1.75
Current - 80 microamps
Impedence - 10kohms.
And they sound rather perfectly equal, too. The 85 is darker and has more low mids, and isnt quite as tight, but the outputs are the same.
What?
I wrote all that?
Sorry :oops:
ilÿti
Damn you MDV... you're selling the Painkillers to me, and I don't even play metal all that much.
Crawlers, Mule-7s
Oh, I forgot to mention - PKs deliver a superb fat crunchy tone and have a decent clean (not as good as a pig, better than a C-pig and way better than a miracle man).
puma_21
Anyone else like Racer X's tone?
Well, PG's tone anyhow...
I love that tone, but maybe with more gain  :D
sorry, MDV, but we'll never agree about anything hahah
the emg 81 has bass, but sounds thin cause it lacks low mids
yes, the MM has a lot more bass AND low mids, but less center and high mids
the difference in output is more in the shock from coming back to the passive sounds
not really noticeable when it comes to punch, mid crunch, attack, clarity
i disagree about you "tonechart" too  :lol:
the pk definitely has more of everything
and the difference in output  between the 81 and 85 is VERY noticeable
I had the ZW set for 2 years
in the neck position, the 85 sounds about 20% louder than the 81 in the bridge
I thought it was the position's fault (more string vibration in the neck)
but in the bridge position, the 85 still sounded louder than the 81
and it definitely pushes the amp input harder than the 81, though being less aggressive
everyone I know that had EMG's complains about this output difference
the major shock I had when I swapped back to passives was missing the EMG 85 output, cause no other pickup I've played had that output
a friend of mine that has a mahogany Dean Mustaine VTMN1 laughed about your output comparison
he had the stock duncan mustaine active set, then an EMG set on that guitar and he says the painkiller set he installed made the EMG 81 sound like a tamed kittie :lol:
Sorry pal, but the tonechart came from playing the pickups in question in the same guitar, same pickup height, A/Bing against reference guitars and through 3 different amplifiers and repeating the process twice (pig/cs out - pks in - pks out - pig/cs in - pig/cs out - pks in - pks out - pig/cs in - pig/cs out - pks in), and changing strings at the end (because of all the buggering with them and the comparision guitars strings were fresh).  Youre wrong *edit - a bit curt there, my apologies, but I trust the closest thing I could muster to a variable-controlled experiment than what youre trying to tell me to hear!!!*.
On the 85: louder is not hotter. Louder is the mids of the 85 coming through more strongly to your ears.
On you mate: tell him I laughed right back, someone mistaking strong midrange pushes effect on the human ear, low end and particularly harmonic overtones for pre amp distortion is a rookie, if very common mistake and I'll bet thats what he's done. It sounds bigger, fatter, fuller, and livelier but not, I repeat, NOT higher gain or hotter.
