Author Topic: Visual Sound V2 Jekyll and Hyde  (Read 4325 times)
  • Truly bad since 1972
« on: July 23, 2008, 10:16:29 PM »
It says reproduces ts808 circuit....
so question one..does it sound like the original Tscreamer (before tweaking buttons)?
question two....noise gate any good?
Re: Visual Sound V2 Jekyll and Hyde
« Reply #1 on: July 23, 2008, 10:20:19 PM »
Erm, I have one but I have never used a Tubescreamer and so cannot give you an opinion- sorry. As for nopise gate...I didn't know it had one :oops: Though as I use minimal pedals I don't get a lot of noise anyway.
« Reply #2 on: July 23, 2008, 10:21:28 PM »
yeah is on dist chanel so is a control for bass(have to adjust in bat compartment I think)
« Reply #3 on: July 23, 2008, 10:41:18 PM »
I have the V2 Route 66, which has the same overdrive, and an early '80s TS9 (not TS808) - but I haven't compared them I'm afraid.  Maybe martinw will chip in, he said on a thread the other day that he compared the J&H overdrive with a number of other Tube Screamer clones, and it was the best of them.
As for the noise gate, from reviews I've read (on HC, admittedly), it seems that it works well but most people turn it off (or down to the minimum level).
martinw
  • Building Amps in the Hills.
    • http://www.mjwamps.com
« Reply #4 on: July 23, 2008, 11:16:48 PM »
Yes, I've got a J&H V2.
The J side is, in my opinion, one of the best TS808 clones around. The benefit is the bass boost which  makes the sound more balanced.
I've compared this with the ususal Ibanez reissues, Keeley stuff, and an Aramat Green Machine which I owned, and to me it was th best.
The noise gate on the H side works well on factory settings but I'll be turning it off when I get round to it.
All in all a great pedal, and great value.
Cheers. :D
Custom Built Amps:
www.mjwamps.com
« Reply #5 on: July 23, 2008, 11:24:16 PM »
Thanks
« Reply #6 on: July 25, 2008, 03:14:26 PM »
I did some mods to a mkI J&H before xmas and it was just 100% a TS-808 circuit before I got my hands on it.
« Reply #7 on: July 26, 2008, 08:48:56 AM »
why what did you change
« Reply #8 on: July 26, 2008, 01:17:40 PM »
the older ones (without the deep switch) lose bass when the pedal is on, I changed some of the caps in the signal path to compensate.
« Reply #9 on: July 26, 2008, 05:55:12 PM »
ahh so v2 sorts that
