Author Topic: PRS SCs  (Read 7198 times)
PRS SCs
« on: July 30, 2008, 07:24:22 PM »
Hello all,
Can someone tell me if there is a difference between a PRS Single Cut and a PRS SC245? I don't know enough about PRSs and am confused!
Cheers
Re: PRS SCs
« Reply #1 on: July 30, 2008, 07:32:55 PM »
They're not making the Singlecut any more, it's been replaced by the SC245 and SC250.
The 245 is like a vintage Gibson, with 24.5" (ish) scale length.  The SC250 is more modern, with the standard PRS 25" scale and higher-output pickups.
Re: PRS SCs
« Reply #2 on: July 30, 2008, 07:35:56 PM »
Cheers Philly. Are they massively different to each other then? I'm guessing not. I've been offered a S/H 245 and am weighing up whether to go for it or not - I've seen cheaper S/H single cuts and was wondering if there were differences in them?
Re: PRS SCs
« Reply #3 on: July 30, 2008, 10:22:48 PM »
I believe the SC250 is pretty much identical to the discontinued Singlecut, except it has different pickups and an adjustable bridge as standard (to allow for downtuning).
The SC245 is basically a lot more vintage Les Paul-ish (since Gibson lost that court case!) - shorter scale, PAF-style pickups, slightly thinner headstock and Kluson-style tuners.  It has the non-adjustable stoptail as standard.
They both have maple tops, thick mahogany bodies and wide-fat necks.
The SC245 seems to get slightly more praise in reviews, but then most reviewers are vintage LP freaks!  I'd have thought a S/H Singlecut is better value for money if it's cheaper, but it depends what features you want.
(I must say I've never played either!  :) )
Dazza1004
Re: PRS SCs
« Reply #4 on: July 31, 2008, 10:38:20 AM »
Both are avaliable with wide thin necks too. Also, the trem versons have thinner bodies.
The satin series are being sold off cheap, I have seen them new for around £1300
Re: PRS SCs
« Reply #5 on: July 31, 2008, 10:48:37 AM »
New SC series are chambered too - the old Singlecuts are not  :)
Re: PRS SCs
« Reply #6 on: July 31, 2008, 10:57:07 AM »
True.  There's no trem option on the SC245 or SC250 though, the Singlecut Trem has been discontinued (unfortunately).
Re: PRS SCs
« Reply #7 on: July 31, 2008, 01:01:32 PM »
interesting definition of "cheap", there... :lol:
Re: PRS SCs
« Reply #8 on: July 31, 2008, 01:06:48 PM »
^ I was thinking that too! :lol:
Dazza1004
Re: PRS SCs
« Reply #9 on: July 31, 2008, 01:14:46 PM »
 :D
I should have said cheap for what they orignally were
Philly, good call with the trem, I guess the tremonti is the only singlecut style with a trem now ?
Re: PRS SCs
« Reply #10 on: July 31, 2008, 01:19:50 PM »
:D
I think the only reason for this is because he has trem at the start of his name.
Re: PRS SCs
« Reply #11 on: July 31, 2008, 01:29:11 PM »
:D
Indisputable logic.
Re: PRS SCs
« Reply #12 on: July 31, 2008, 01:39:23 PM »
:D
 :lol:  Mark Tremolo-onti.
Yeah, there's still the SE Singlecut Trem of course.  They seem to be using the SE range for "alternative" models, rather than it just being a budget version of the US range.  Which is good, but I quite fancied a "proper" Singlecut Trem.  I suppose it wasn't all that different from a Custom 22, apart from the neck joint - and PRS seem keen to keep the range as streamlined as possible, without any superfluous models.
Re: PRS SCs
« Reply #13 on: July 31, 2008, 07:48:29 PM »
anyway - the SC245 I have been offered is going for £1500.00. Good deal or not?
Re: PRS SCs
« Reply #14 on: July 31, 2008, 09:47:19 PM »
:D
still, that can be dodgy logic... often prices are inflated so that when they drop them it appears you're getting a good deal. :)
Indisputable logic.
indeed. :lol:
