Is this a potential body blank?
Started by MrBump, August 03, 2008, 11:07:50 AM
I nearly added "I suspect Philly's the same..."
I also suspect that even chaps like Wez, Jonathan, etc must have at least one or two items like this lurking in their past!
Quote from: AndyR on October 05, 2008, 11:25:05 AM
I am.  But it's also true that one of the reasons I've never stepped up to building guitars "from scratch" is the cost of tools and equipment.  I do nearly all my little bits of tinkering with basic hand tools (including some of StewMac's excellent gadgets).  I don't even use an electric drill if I can avoid it.
Must say though, my trusty old Black & Decker router is one of the best investments I ever made.
Yep, my biggest cost was the B&D Router - it's fantastic.
I first tried to route using my Dremel + router attachment.  Killed it.  And it cost more to repair than replace.
So, replaced that with a cheapo Maplin dremel-esq thing.  OK, but nowhere NEAR as good as the Dremel.
Then bought a dirt cheap plunge router from Evil Bay...  the thing was just sooo wrong...  turned it on, it started flying around at about a million rpm, sparks started to fly out of the back of it.  I was genuinely scared.
Then the B&D and all was fine.
TBH I have a lot of other stuff, a decent drill etc.
If I were to do it again, I would invest in:
1. A decent work bench.  The B&D Workmate just doesn't cut it.
2. A drill press.  It's impossible to drill in a straight line without one.
3. A band saw.  I know, really expensive.  But a jigsaw is RUBBISH and painfully slow.  Also, I can't see how I could make a neck without a band saw and a straight cutting line...
I think that it's possible to do a lot with few tools if you're prepared to ignore some pretty fundamental safety guidlines...
Mark.
Quote from: MrBump on October 05, 2008, 12:50:28 PM
Yeah, a band saw, that's the big investment!  I'd love to own one, but if I did feel inclined to purchase, the only place I could keep it would be the kitchen... ain't gonna happen.
I do have a really primitive spring-loaded drill press, but it's very hard to hold it in place and drill at the same time (at least until I manage to grow a third arm :roll: ).  I much prefer to use my hand drill whenever possible.  Sometimes I use the drill press and power drill to make a template, then I can switch to the safety of the hand drill and still get a proper vertical(ish) line.
This is one of the best lines I've read recently - kind of sums up my entire experience of DIYery. And it so easily covers both extremes:
"... it's possible to do a lot (of good stuff) with few tools ..."
"... it's possible to do a lot (of damage to the precious item you are working on, to the kitchen worktop, the living-room carpet, passing relatives, next-door's mains supply, and so on) with few tools ..."
:D
on my first i had a cheap drill and i brought a basic router for doing the truss rod slot... everything else was hand tools - inclusing cutting out the body from a 2" slab of mahogany with a coping saw.  it was the first proper wood work i had ever done but still turned out playable and sounded great
And so, as a finale, to this great thread, some not so great playing.
This is the thing spanking out a tune:
http://soundclick.com/share?songid=6947937
A bit of VH inspired guitar-w**kery, complete with dodgy drums.  I had to tweek the EQ on my amp big style to tame the brightness, but it's still cool to play.
Mark.
Would look so much better without that horrible pickguard, kinda ruins the look a bit imo :(
Quote from: _tom_ on October 16, 2008, 03:29:55 PM
Yeah, it's pretty bad...
The idea was "cheap build"...  I just used the bit I had, where I had them.  And I wasn't really confident enough to route a pickup cavity.
I kinda like it though.  Not pretty.  But I like it.
WITH FULL DISTORTION
great stuff mr bump
q:p
is that clip , already with a BKP installed on it?
just to confirM or not that the brightness is something purely related to the Body wood(s), instead of the pickup.
Q:)
JP
Denim n Leather
Well done; looks awesome, imo. I like the sound, too, from what I could hear of it. :)
No, it's a terrible clip!  It's a Tone Rider Rocksong humbucker - gonna change it for a "heavyish" BKP ASAP...  Not sure which one though, possibly a Warpig.
Mark.
i actually really like the headstock shape
buttmonk
#59
Quote from: WezV on August 03, 2008, 08:12:50 PM
brian mays red special was an oak mantlepiece
Yes, was gunna say the same. I think it was also made from several pieces glued together, and if I remember was somewhat hollow and contained some sort of resonation chamber.
