Author Topic: ibanez 7 string question  (Read 2158 times)
JRM75
« on: August 03, 2008, 02:43:03 PM »
Hi all,
I am tossing up whether or not to get a 7 string for a bit of mucking around with lower tunings, and my question is 2 fold i guess.
 does anyone know how the ibanez goes with heavier gauge strings?  and also how much difference would there be between a 25.5" and a 26.5" scale neck on the string tension, the reason i ask this is because i was thinking about maybe looking a schecter hellraiser 7 FR, if the i didnt like the ibanez.
cheers Jason
EDIT: i am looking at the Ibanez s7320.  This additional information will be helpful i guess
« Last Edit: August 03, 2008, 10:32:23 PM by JRM75 »
Re: ibanez 7 string question
« Reply #1 on: August 03, 2008, 05:02:53 PM »
Which ibanez?
« Reply #2 on: August 03, 2008, 09:43:32 PM »
Schecter Loomis!!!!
« Reply #3 on: August 03, 2008, 10:19:09 PM »
I have an Ibanez RG470F (6 string) which I've loaded up with d'Addario Jazz strings (EJ22) tuned to A-E-A-D-F#-B. The low string is a touch on the flappy side, but in general the guitar copes pretty well. I'm looking at going custom, though, just to make sure the low tunings are optimal, as I play quite a lot of fastish riffs low down, and the string tension could use being a bit better.
Not sure if that helps you or not :)
Roo
JRM75
« Reply #4 on: August 03, 2008, 10:30:08 PM »
Which ibanez?
S7320
thought i had put that in the body of my message, oops
JRM75
« Reply #5 on: August 04, 2008, 02:39:26 AM »
Roo
helps a little bit thanks.
Lazy_McDoesnothing
  • wi, usa
« Reply #6 on: August 04, 2008, 07:24:47 AM »
This thread seems pretty relevant:  http://www.sevenstring.org/forum/sevenstring-guitars/63769-so-my-ibanez-cant-take-larger-string.html
Are you planning on going back and forth between lower tunings and standard with the heavy strings?  That's probably not a good idea but if you're just sticking to low tunings by all means get heavy strings.
JRM75
« Reply #7 on: August 04, 2008, 10:09:24 AM »
Thanks for the link.  I will be just sticking with low tuning, i already have a PRS custom that i use for standard tuning.
cedrac
« Reply #8 on: August 05, 2008, 08:23:10 AM »
Hello,
I have an Ibanez s7320 with Nail Bomb in bridge.
I test some differents gauge, the best (for me) with a classic tunig (B E A D G B E) is :
010-013-017-030-044-052 from GHS TNT and 062.
Les Fils du Mekong : "Not typical metal with a twist of avant-garde"
