Author Topic: Who makes the best Push/Pull (or Push/Push) pots?  (Read 24430 times)
il˙ti
Re: Who makes the best Push/Pull (or Push/Push) pots?
« Reply #15 on: August 26, 2008, 09:29:10 PM »
What's a push/push pot? And what would you usually use one for? I know all about push/pulls, know ziltch about push/pushes
Push it and it switches, push it again and it switches back. Like the stomp switch on pedals. You'd use it for exactly the same as push/pulls I assume.
Crawlers, Mule-7s
« Reply #16 on: August 26, 2008, 09:37:49 PM »
Exactly.  And it's easier to use, because you don't have to worry about sweaty fingers slipping off hard-to-grip knobs (oo-er).  :D
« Reply #17 on: August 26, 2008, 09:48:19 PM »
I would assume the PRS one should be decent quality?
http://www.thomann.de/gb/prs_acc_4108_push_pull_poti_500.htm
PRS push/pulls are very good.  As they should be at the bloody price they charge for them!
badgermark
  • Mm-hai!
« Reply #18 on: August 26, 2008, 10:35:48 PM »
Interesting! I want to try something like that out, but alas I am a simple person with simple needs.
