why can i not delete my own posts anymore?
Started by opprobrium_9, August 10, 2008, 03:31:24 AM
opprobrium_9
It would certainly be good in the seconds out section when something sells
Deleting the listing would tidy up that section for sure
i dont see why it matters, i'm probably quite bad for doing late night drunk posting  - but i can edit them if they are really bad.   generally i go by the rule of not typing anything i dont want on permanent record
Someone should create a USB breathalyser for computers
If you have had a few drinks it shuts down your PC before you start flaming peeps on forums
Quote from: FELINEGUITARS on August 10, 2008, 12:12:34 PM
If you're drunk enough to start drunken flaming, what makes you think you would stop to use a breathalyser?
The term "Ima not dwunk" comes to mind.
Quote from: noodleplugerine on August 10, 2008, 11:41:09 PM
You only drink I'm thunk!
opprobrium_9
Quote from: WezV on August 10, 2008, 11:51:18 AM
Well for instance if there is an error an you do a double or more post.  It is just nice to be able to clean that up.
