Author Topic: Bigsby's, teles, & Hiscox cases  (Read 12958 times)
The amazing Phil
« on: September 19, 2005, 03:49:42 PM »
Ok,
so I happened upon the idea of slapping a swiggle bar on a tele by modifying the 3 saddle bridge to accept strings from behind rather than under, but wussed out through lazyness and not wanting to wreck a useful component like the bridge.
But, I've plucked up the courage to get a Bigsby and try this, but I'm not sure if the bigsby will fit in the hiscox case I have! Does anyone know of a hardshell case that would accomodate a bigsbyfied telecaster?
« Reply #1 on: September 19, 2005, 05:02:50 PM »
I have a TKL teardrop case taht came with my Reverend. It has a Bigsby and fits nicely. I'm sure a Tele with Bigsby will fit too.
I'm not sure if you can get 'em at TKL but you could try to order one from Reverend.
R/2e
    • http://www.ron2e.com
« Reply #2 on: September 20, 2005, 11:03:47 AM »
The Tele with Bigsby won't fit in a Hiscox Fender size case, I have both and I've tried. The Tele now travels in a gigbag.........
The amazing Phil
« Reply #3 on: September 20, 2005, 02:44:21 PM »
Hmmm, looks like it could be quite a search then. I imagine feder might do one, I suppose I'll have to hassle them about it.
« Reply #4 on: September 20, 2005, 09:00:49 PM »
Quote from: The amazing Phil
If they make a case for the John 5 signature Tele.......
willo
« Reply #5 on: September 20, 2005, 09:10:15 PM »
Quote from: Ratrod
although the headstock is a slightly different shape on the J5 tele, isn't it?
« Reply #6 on: September 20, 2005, 09:15:21 PM »
Quote from: willo
Quote from: Ratrod
Yeah, it's longer and has three tuners per side. The longer headstock makes for easier bhind the nut bending. Still I think a normal Tele will fit.
