Author Topic: Amp making weird noise!  (Read 4976 times)
TomW
    • http://www.myspace.com/wolfiosg
« on: August 27, 2008, 01:07:39 PM »
My jcm800 has just started making a really weird noise. I've attached a recording of the sound its making, it seems to be humming really loud and has a sort of scratchy noise all the time even with the volume all the way down. I've tried different guitar leads, guitars and with no guitar at all and the noise just won't go away. I've also tried moving the amp away from electrical objects but still no luck.
Any ideas as to what it could be?
Cheers
Riff Raff/Stormy Monday, Holydiver and Mississippi Queen!!!
www.myspace.com/therealamorist
hamfist
Re: Amp making weird noise!
« Reply #1 on: August 27, 2008, 01:49:32 PM »
It's very likely to be a tube. You'll need a known good 12ax7 to swap in for each of the pre-amp tubes in term, to find out if it's one of them that's faulty. Otherwise, you'll need to try another set of EL34's - if it's just for a minute or so, you won't need to bias them, so you can just borrow a "mate's" set if you want to try them out - just keep an eye out for any red-plating if you're quickly trying any out without re-biasing.
TomW
« Reply #2 on: August 27, 2008, 02:17:51 PM »
Cheers hamfist, I've got a couple of spare EL34's so may give that a go if I'm feeling brave, but i'll have to send it to an amp tech anyway to get it rebiased properly, so might just get them to check it out to be safe.
QS-Nalle
    • http://www.tubesound.fi
« Reply #3 on: August 28, 2008, 07:07:26 PM »
What it could also be is a bad solder joint or a cap going bad, but start with the tube. 99% is tube related. :o
Gary
    • http://www.uploadedtheband.com
« Reply #4 on: August 28, 2008, 08:29:26 PM »
Would this be true even though it's still happening with the volume all the way down?
hamfist
« Reply #5 on: August 28, 2008, 09:27:31 PM »
Good point Gary.  As it's a JCM800 (pre-PI MV), if it's a tube problem that narrows it down to the PI (V3, the 12AX7 nearest the power tubes), or the EL34's themselves.
Just a hunch, but it sounds similar to dodgy power amp tubes I've had in the past.
