Author Topic: Strat fret buzz/ DIY hardtail?  (Read 7210 times)
Mark66
« on: September 04, 2008, 11:12:22 PM »
Strings on my strat are buzzing, even with fairly high action(2-2.5mm at 17th fret) and slight neck relief. I don't
want to go any higher, but can't figure out how else to get rid of fret buzz, or should I just put up with it?(use .010s)
Maybe a pro set-up is in order, anyone know a good tech in Yorkshire?
Also, to turn my strat into a hardtail, I screwed the bridge down to the body and put in 2 more trem springs. This worked ok, but when I replaced the backplate, it's cut-out slot was out of line with the string holes in the steel block, meaning I have to remove the backplate to change strings. Does this mean I have to do a Clapton job on it with a block of wood to keep things in line? Much of a job?
Re: Strat fret buzz/ DIY hardtail?
« Reply #1 on: September 04, 2008, 11:53:03 PM »
I would have a pro setup with a fret dress
As for the backplate - why not try this one
http://www.allparts.uk.com/tremolo-spring-cover-access-panel-p-4174.html?p=product#
Or have a standard one made with a doctored slot to allow easier access to the holes in the trem
Mark66
« Reply #2 on: September 05, 2008, 05:09:13 PM »
Thanks Feline, pro set-up it is. It's not had one in the 3 years I've had it from new, just my own(rather limited) adjustments. Anyone know of a decent tech in Yorks?
Not so sure about that backplate. Where could I get a standard one made? (Could probably cut the slot myself if
I could find a solid one)
« Reply #3 on: September 05, 2008, 05:44:50 PM »
We'll do one for you if you like
Just make it with a wider slot to allow ease of stringing
Can you take a piccy of the existing one so I can see how much I need to doctor the new one
Mark66
« Reply #4 on: September 06, 2008, 01:01:29 AM »
I think I'll try widening the slot on my existing backplate. If I muck it up I'll be in touch Feline.
« Reply #5 on: September 06, 2008, 10:43:31 AM »
Cool stuff - hope it comes out fine
Mark66
« Reply #6 on: September 12, 2008, 02:24:06 PM »
I doctored the backplate slot, tidy job, works a treat :D. Going in for set-up next week.
« Last Edit: September 12, 2008, 02:25:57 PM by Mark66 »
« Reply #7 on: September 12, 2008, 04:27:41 PM »
Well done !
Hope the setup works a treat!
