help with pg's
Started by duanesworld, September 10, 2008, 02:50:55 AM
duanesworld
Hi, I just bought a set of pgs and had my tech put them in a ibanez as50. The bridge sounded great, the neck was thin and had no low output. He disconnected it and wired the pickup to just a jack and plugged it in amp, and it still sounded thin and weak. he measured it and it was 7.1., does anybody have any suggestions?thanks,Mike
duanesworld
maverickf1jockey
Did you have four conductor wiring?
If so it might be worth taking a look to see if you have soldered the right wires to the right posts on the selector and the pots just to be sure.
duanesworld
just regular braid. thanks
kellar
I have had nearly every problem imaginable with pickup wiring. Weak signal, no signal, cuts out, thin, whatever. Obviously that doesn't say much about my soldering skills. :(
But, I have fixed the problem 99% of the time by resoldering everything very carefully, making sure each point is firm and properly grounded. It can be frustrating, but in my experience the problem is almost always a bad/improperly soldered joint or bad ground.
duanesworld
thanks. I would agree, but after just connecting it to a jack and bypassing everything and its still sounds the same, I don't believe its the soldering.
It's possible (but not probable) that one of the coils is broken/shorted. Did you contact BK directly about this yet? If not, you should do so -- they have the best customer service around! Let us know what happens!!
kellar
Quote from: duanesworld on September 11, 2008, 04:51:33 PM
Right, than that would suggest that perhaps you have a faulty pickup. I agree with the above, I would definitely give Tim a call.
viking
I recently bought a VH2 set and one of the coils (neck pup) was broken.My luthier didn't know if he was responsible but he send it back to BKP.It took a few weeks but they fixed it.
