Maiming my strat.....or healing it :-)
Started by Multani, September 22, 2008, 10:29:33 PM
Multani
Well, i will probably regret this in 30 years time when my metabolism has slowed down and i decide to play blues. But for now i am playing contempory metal/hard rock. And the strat aint playing. It has such a puny output it is rediculous, even with a tubescreamer. Great for jazz/blues, but anything demanding pinch harmonics and its no show.
At the mo' i have a mahogany washburn with a war pig and i love everything about it. The strat in concern is a made in japan model from 1994-95. It was my first electric 7 or so years ago but for the past 4 its just been sitting in a case. So i thought id renew its commitment to me by bar-stewardising it with some bareknuckles!
I couldnt tell you exactly what the body is but neck is definately maple. Body might be basswood. or maybe alder. im leaning to basswood for MIJ though.
So i guess i want a hot output humbucker (routing needed i know...) with not too much "hi'"s, seen as this seems to be a pretty twangy guitar in its own right. this is the sound im diggin right now-
www.myspace.com/heislegend
This would work alongisde my washburn. One would be in drop D/ E standard and the other in Drop C/ D standard territory. Cant really decide wich is which till i here 'em both.
Fire away lads :shock:
You should look under the pickguard, most modern strats are route HSS from factory :D
Modular1
my fender usa came routed for HSH. i believe most are. could't say for a MIJ tho.
Stick a holy diver in it! you wont regret it!
gingataff
Or you could stick with singles and get an UberSinner.
I see a rainbow rising
Look there on the horizon
And I'm coming home
Or you could just accept your fate and play the blues...
I'd go Sinner.  Strats are meant for single coils.
Mark.
I'm with Mark on this one. I'd suggest you think about and consider the hi-output singles first - doesn't mean it's not valid to go the humbucker route though :D
I messed around with an early 80s JV Squier (in the early 80s, and then again in the 90s), I kinda regret it now. I was trying to make it do something other than it was good at. It's still a cute guitar, but its not what it was, and its just not worth the time/effort/money to restore it properly.
I've not tried the higher output BKP singles myself, but if I wanted to push a strat to its limit now, I'd get the sinners with baseplates. Sooner or later you're going to want a strat that sounds like a strat as a contrast to the mahogany/warpig. Perhaps, think about whether it's this one or not... :)
Nah, put a humbucker on it.
That's one of the great things about a Strat - you can always just swap the scratchplate in 30 years when you turn into Walter Trout.
I would put a nailbomb, just because of the clip that Tim recorded with it...
A Ibanez is nothing else than a strat with humbuckers and floyd rose...
Woogie
kellar
Play the blues man. Just play the blues. :D
Woogie
Cool, I was considering a HD for my Strat.  And/or a VHII.  :)
Multani
Cheers lads. I am well up for a humbucker. So sorry for the singlecoil fans!
I just realised that Devin Townsend (basically my idol!) recorded his newest album with an american strat with a Seymour duncan pearly gates stuck in the bridge.
Will the holy diver get me into that sorta territory? or nailbomb it>?
i guess it would be outta those two and the miracle man or painkiller.
Modular1
holy diver will get you nice cleans... and it will do metal too
