Author Topic: Pickup Rings for SG200  (Read 4305 times)
« on: October 07, 2008, 12:44:56 PM »
Quick question - my Yam SG 200 has 3 screws in each pickup ring holding the pickups.
I haven't opened it yet - I'd assume it's pretty straight forward to replace the rings?  Are "angled rings" all angled to the same degree?  Or will I need to sculpt the rings to fit a curved body?
Or would I just drill another hole in the existing rings to accommodate?
Cheers.
Mark.
Re: Pickup Rings for SG200
« Reply #1 on: October 07, 2008, 12:55:07 PM »
either way works,
if it was a carved top you would maybe have a little more fitting if you changed the rings but i wouldnt worry about it on a flat top guitar
« Reply #2 on: October 09, 2008, 11:16:40 AM »
I switched mine when I switched to BKP's. The stock pickup rings won't work with BKP's. They're not wide enough and they have three adjustment screws instead of two.
I took my SG to a guitar shop and test fitted several pickup rings.
« Reply #3 on: October 09, 2008, 09:35:59 PM »
Cheers, Mr Rod.  Did you need to get any of the wood chisled away too?
« Reply #4 on: October 10, 2008, 11:31:16 AM »
No, I didn't need to chip anything away.Buti t was a tight fit. I did have to drill new holes for the rings.
