Author Topic: Adding effects loop M/V amp  (Read 1911 times)
  • Truly bad since 1972
« on: October 10, 2008, 09:33:29 PM »
How easy is it to add a effects loop to a master vol amp.....in simple terms do you add a tap on the wire going to master volume, 2 switched jacks one from the pre and the other the return to the power.(so if no jacks in signal not interupted)
I know slightly more to this I.E. some kind of way to adjust level...but is this the theory
Re: Adding effects loop M/V amp
« Reply #1 on: October 11, 2008, 01:20:49 AM »
you could do it that way, it's the most simple way.  however, you could also have a unity gain stage driving the 'send' and a gainstage after the 'return' jack to boost the signal up to counter any losses.
« Reply #2 on: October 11, 2008, 08:02:45 AM »
I was with upto the point when you said "you could do it that way" have to look the other bits up
