Author Topic: Warmoth question  (Read 2880 times)
kellar
Warmoth question
« on: October 13, 2008, 04:30:31 PM »
I have been thinking about putting together a Warmoth LP. I noticed though that they only offer bolt on (unless I overlooked something). I guess my question would be if there are any serious disadvantages to this? I have always played LP's, and they have always been set-necks. With all the money it would take to do my own build, would it really be that smart to settle for a bolt-on when I could probably spend the same amount of money on a decent set-neck LP?
I am just starting to get into guitar building/working on my own guitars, and am curious to know if a bolt-on holds any true disadvantages. Thanks in advance for the feedback. :D
Ben_W
Re: Warmoth question
« Reply #1 on: October 13, 2008, 04:38:14 PM »
Take a look here, it should help you out a bit. :)
Cold Sweat, Irish Tour, Miracle Man
« Reply #2 on: October 13, 2008, 04:38:27 PM »
Never had an bolt-on LP, but I'm on Warmoth forum too and there is two major feelings about it there:
1) It change the tone. will give you a more '70s tone...
2) Don't change the tone...
If you get a fatback or '59 roundback I think the difference will be smaller, but if you get a very thin Wizard neck, will be a difference...
Just to add, that difference in tone is no disadvantage, just difference...
For that advantage side I think a bolt on neck is more advantage because you can just change it if you brake the headstock or anything else...
That is the only think I count in that side (that I remember now :roll:)
EDIT: From Warmoth I would have a bolt-on LP, but for custom would be set-thru or neck-thru...
« Last Edit: October 13, 2008, 04:40:42 PM by FernandoEsteves »
kellar
« Reply #3 on: October 13, 2008, 04:52:50 PM »
Good info guys, thanks a lot!
Has anyone here built a Warmoth LP with a bolt on neck? I did search the forum, but it seems that most have built Strats or other styles, couldn't find an LP build. Just wondering about the outcome.
« Reply #4 on: October 13, 2008, 06:57:13 PM »
Ted has a Warmoth SG.
Not the same as an LP of course, but it is a Gibson-type with a bolt-on neck - if you search for "warmoth" posts by "Ted" I'm sure there are quite a few pictures etc.
kellar
« Reply #5 on: October 13, 2008, 07:24:06 PM »
Thanks a lot Philly Q, I will give that a try.
« Reply #6 on: October 14, 2008, 12:43:04 PM »
I have had 2 Warmoth LP bodies, one was a double cutaway junior that I bought in the early 90's in Honduras mahogany, and the other is an all mahogany that I bought earlier this year.  In both cases I got them with no neck pocket cutout.  I had a friend copy my 1960 LP Special neck and fit it to the Junior body, and the mahogany one is having a custom neck made by Will Scott Guitars (this will be a Marc Bolan LP clone).  So in both cases I have set necks on them.  There are lots of people who say a properly made bolt on is as good (or better) than a set neck, but on Les Pauls I think the set neck looks better!
