Author Topic: Intonation problem  (Read 5981 times)
Stevepage
Intonation problem
« on: October 14, 2008, 11:45:39 AM »
Hey guys. Recently I got a Gothic V. It's fantastic but I'm having trouble getting the low string to intonate. It's tuned to C standard with a 62 on the low C. When I fret a note at the 12th fret, it's slightly sharp. Usually I would just tighten the intonation screw at the bridge but it's as far back as it can go, yet it's still out of tune.
What can I do to rectify this? Would a slightly lighter string fix this problem?
Re: Intonation problem
« Reply #1 on: October 14, 2008, 11:59:21 AM »
I'd live with it.
Or you may be able to flip the saddle the other way round to give you that extra little bit of adjustment?
Stevepage
« Reply #2 on: October 14, 2008, 01:23:22 PM »
Thing is, when you play a chord, you can hear that it's out of tune. The saddle is already set up the other way round and can't move it any more
« Reply #3 on: October 14, 2008, 01:29:31 PM »
Ah.
You may want to look at other TOM bridges.  Some are wider than others and may give that little bit of extra adjustment?  Maybe a TonePros or similar?
Jonathon at Feline may be able to help with which might suit...
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #4 on: October 14, 2008, 02:20:28 PM »
Would a nashville type give more room for intonation?
I see a rainbow rising
Look there on the horizon
And I'm coming home
« Reply #5 on: October 14, 2008, 02:23:20 PM »
That's what I was thinking.....
Stevepage
« Reply #6 on: October 14, 2008, 03:43:29 PM »
How can I tell if I haven't got one already? Or is the Nashville bridge something that just doesn't come stock on Gibsons?
« Reply #7 on: October 14, 2008, 04:48:24 PM »
They either have Nashvilles or something I can't remeber the name of  :oops:
being a recent Gibson, it may well be the larger Nashville that you have.  I'd give Jonathon a call at Feline and see what he suggests...
« Reply #8 on: October 14, 2008, 05:49:06 PM »
The old style Gibson bridge is an ABR1.  The Nashville is wider and the Schaller from the early 70's is wider still!
Top is a Nashville, battom and ABR1.
« Last Edit: October 14, 2008, 05:52:04 PM by PhilKing »
« Reply #9 on: October 14, 2008, 05:53:47 PM »
ABR-1.  But it's a Nashville on the Gothic V.
The Nashville bridges usually have the flat edges of all the saddles facing forward, so you could get a tiny bit more string length by turning that saddle round (edit - sorry, just re-read and saw it's already set that way  :oops: ).
But the problem is the heavy string - if you're always going to have strings that heavy you could maybe get the bridge relocated?
Edit:  Maybe a 70s style bridge like Phil mentioned would do the trick:
http://www.allparts.uk.com/tunematic-bridge-style-p-4279.html?p=product
« Last Edit: October 14, 2008, 06:00:08 PM by Philly Q »
Stevepage
« Reply #10 on: October 14, 2008, 06:17:15 PM »
Ok I don't know how I did it, but I've fixed the problem. Here's how:
Get so annoyed and frustrated, give the bridge a bit of a thump and BAM!
Fixed!  :lol:
It's now sounding fine all over the neck.
« Reply #11 on: October 14, 2008, 06:23:41 PM »
if in doubt... give it a clout!!!
... then send it to me for repair!!!  ;)
