For a very basic in and out it's easy. The problem is you need some way of dropping the level so it won't overdrive your effects, and then a way of boosting the level back up after your effects. To be able to do this you either need anoher valve or some chips to buffer and drive the effects loop.
www.tubeampdoctor.com sell a variable FX loop kit that can do this.
